ABS brakes
Old Dec 9, 2000 | 05:31 PM
Donald Duckk
Does every GLE come with ABS brakes? If not how do I tell if I have them or not?
Old Dec 9, 2000 | 07:35 PM
Mike Cline's Avatar
My 95 GLE does not have ABS. As for newer Max's, I am not sure if they are standard on GLE or not.
Old Dec 9, 2000 | 08:00 PM
theblue's Avatar
while we are on the subject of ABS... is the maxima ABS system a 4 wheel ABS or just the rear?
Old Dec 9, 2000 | 08:09 PM
black96se's Avatar
ABS?
I have an idea on how you find out if you have it....go to a parking lot when it is wet or snowy and hammer the brakes, if the pedal vibrates than you have ABS
PS - I'm loving this Toronto snow, working on perfecting my e-brake turns
Old Dec 9, 2000 | 10:01 PM
Chunger's Avatar
My other car is a Hybrid
ABS is normally packaged with the
Leather trim... It s/b a 4 channel system...
I believe all 5th gens get it standard...
Wanna know if you have it? Check for the ABS light when you start the car...
Old Dec 10, 2000 | 08:08 AM
plrod Black 95 SE's Avatar
I don't think it's standard
I know I don't have them. I also don't have leather interior. Probably the easiest way to tell is to look in the engine compartment and follow the brake lines from the master cylinder to see if there is an ABS box somewhere.
Old Dec 10, 2000 | 09:19 AM
MaxRX7
ABS is a $500 option on any 4th gen.
You can remove the wheel and rotor and check for the ABS unit, but if you do not know your ABC's then just go to a long empty space and slam on the brakes a few times. If the wheels lockup(the car slides) at least one time you do NOT have ABS.
Old Dec 10, 2000 | 11:17 AM
Maxima95GLE's Avatar
ABS info on 4th and 5th gens
To put this post to a definitive end---the 4th gens did have them as a $500 OPTION on the cars. And from my reading, ALL 5th gens have ABS as a STANDARD safetey feature.
Again, the easiest and safest way to check to see if you have ABS w/o even starting your car, is to do either:
1) <easiest method> turn your key to ON (but don't start your car!), and watch for the diagnostic test lights in your instrument cluster to light up. If you have ABS, it will be an orange light on the left side, it'll stay on for about 1-2s, as it does its diagnostic.
OR
2) look under your hood and check to see if there is an ABS actuator underneath there. On my 95 GLE, it's located right in front of the master brake cylinder. From the looks of it, it looks like a 4 channel system.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
