NE1 know how to configure it a S-AFC on a maxima???
Originally posted by BrokenMotor
I just picked up a S-AFC, got it all hooked up and everything, now all i need is someone help me configure it.
You need to set the engine type to "6" and arrow pointing up to the right. The air flow sensor type should be set to Hotwire (HW) Type 4 (HW4).
Under Hi/Lo Throttle settings, set Lo to 39% and Hi to 40%. Don't make any airflow changes in Lo. Only make changes to the Hi setting. This will prevent your changes from being dialed back out in the ECU's closed loop mode. The only way to really dial in the changes in Hi is via dyno tuning. You can try by feel but I guarantee it's not going to work out too well. FYI if you find yourself dialing in more than +/-15%, you're way out if your car is normally aspirated (no nitrous, no SC).
FYI the english translated manuals are downloadable (Acrobat form) on the http://www.apexi-usa.com website.
Originally posted by Gotrice4
How much did u pay for the S-AFC? How hard was the install? And what is involved to install it, what lines need to be spliced and what not...
i got the AFC from my friend. well...as far as installing it isn't a problem, it only took us 30mins. you need to download the wiring diagram from http://www.apexi-usa.com. or i can e-mail you everything you need for you later on. =)
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
