Climate Control
Old Jul 18, 2002 | 05:29 PM
SonicDust187's Avatar
Climate Control
If there is a Maxima whose condition only works when it is set to level 4 but doesnt work when you set it at level 1, 2 or 3. What can be the problem and how much is it to fix?
Old Jul 18, 2002 | 06:42 PM
markus876's Avatar
Exact thing happened to me a few days ago. Don't worry, its an easy fix.
Look where the front passenger puts thier feet. There will be a decently sized plug pluged into a thin-ish resistor. The resistor is almost certainly the fried part.
You can get a replacement resistor from Maxima for pretty cheap, and replace it yourself. Just pull the plug out, unscrew the one screw holding the resistor plate on, replace, and put it back together. Should work fine after that.
Old Jul 18, 2002 | 06:45 PM
Are you sure cause it needs to be replaced tomorrow. How much is it? Is there a way to tell if it is it or not? Thanks.
Old Jul 18, 2002 | 06:56 PM
markus876's Avatar
Well, im not gonna bet my life on it obviously, but I had the EXACT same symptoms. You can check it by unscrewing the resistor and taking it out and taking a look at it. Mine was obviously burned out.
It makes sense from an electronics standpoint too - setting for 4 works because that is just straight juice to the fan, no resistance, and if you turn it off, it will turn off, which leaves the resistor being really the only other part that could be causing problems.
Edit: I dont know how much the part was, I just bought my car ('95 GXE 5spd, woot!) from a used lot and when I noticed the fan only worked on '4' they bought the part for me. I took it home to install it because their mechanic wasn't their and the guy there thought it could take up to an hour to do the install (I think he figured you had to take the dash apart to get at it, which i did later, and then only after spending 30 minutes unscrewing things did i realize where the part really was . Actual install once i knew to look in the right place? 2 minutes.)
Old Jul 18, 2002 | 07:07 PM
Thanks. Ill take a look tomorrow.
Old Jul 18, 2002 | 07:15 PM
On which side of the passenger foot area is the plug, (left, right or straight)?
Old Jul 18, 2002 | 08:44 PM
markus876's Avatar
sit in the front passenger seat.
stretch your legs out nice and comfy like
now, kick upwards with your right foot, thats where the fuse will be.
There will be a visible wire with a plug that attaches to it, about 2inchs by 1/4th of an inch in dimension.
Old Jul 18, 2002 | 08:45 PM
Thanks Ill check it out.
Old Jul 23, 2002 | 12:03 PM
When you had your problem, did it go like you turn it to 4th position it would work and then cut of. Thats what happens to me. It works for 10seconds, then it turns off, i wait for like 30 seconds and turn it back on, and this happens over and over.
Old Jul 23, 2002 | 12:43 PM
BrianV's Avatar
What do you mean set to level 4? You mean fan speed?
I have mine on Auto all the time and it works alright unless it's really hot outside then it sucks.
Old Jul 23, 2002 | 12:53 PM
Yes the 4th level, I have manual controls.
Old Jul 23, 2002 | 04:17 PM
BrianV's Avatar
Then why is the topic called climate control? It shoud be 'HVAC Problems'
Climate Control is an option on the Maxima that allows the user to set a temp and the system using sensors will achieve and maintain that temp without any user intervention.
Old Jul 23, 2002 | 06:29 PM
I am sorry for the mistake of calling it climate control, but I can not change the name of the topic right now. It was the resister. Thanks for everyones help. However I still have one more problem with the AC. It will work perfectly for a while and all of the sudden turn off. I switch it to off and turn it back to the position that I like and it works perfectly. And after a while it happens again. Anyone know what might be the problem?
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
