Help!! how to install stillen oil cap??!!
Old Jul 19, 2002 | 02:23 AM
Draino's Avatar
I'm sorry but this was kind of a joke. Just curious who would actually help someone with this problem.
Old Jul 19, 2002 | 05:37 AM
njmaxseltd's Avatar
Some tips on installing aftermarket oil caps:
1) Never use your stock oil with aftermarket caps. It will ware out just like stock struts do when you use them on lowering springs.
2) You need 4 floor jacks with wheels and 4 friends.
3) Jack up all 4 corners of your car with the floo jacks.
4) Hold oil cap securely over oil fill hole.
5) Have your 4 buddies rotate your car counter clockwise while you hold the oil cap in place. This will tighten it up.
(This is the same procedure the Polish use when changing light bulbs.)
Old Jul 19, 2002 | 06:12 AM
redmaxpa007's Avatar
i SeE what you did therE
i will have to try this.. and i was using my hands to turn the oil cap instead of the car.. jeez... i feel silly..
Old Jul 19, 2002 | 06:25 AM
Axra's Avatar
6) Make sure to torque it to 12ft-lbs to ensure proper sealing.
BTW: How many lbs does it take off the car. If I get one what kind of time improvement can I expect to see at the track?
Old Jul 19, 2002 | 06:37 AM
nathan179's Avatar
You should get the 15-20 HP's that you thought you could only get with flaming dragon vinyl stickers and those Type-R replacement badges.
Old Jul 19, 2002 | 07:24 AM
orgasmicNYC's Avatar
Why would you have your friends rotate the car? You can just rotate it yourself using your hands
Old Jul 19, 2002 | 07:40 AM
SleeperSE's Avatar
- Don't forget to do what the Haynes Manual says and "Disconnect the negative battery terminal."
- Don't forget a new gasket set, too. I forgot to when I got my nifty Stillen oil cap and oil leaked all over my vinyl sticker set AND my brand new red Honda badge!
Old Jul 19, 2002 | 07:51 AM
njmaxseltd's Avatar
Old Jul 19, 2002 | 08:40 AM
MDr's Avatar
MDr
Stillen oil cap is a great heat sink device (AL tranfers heat better than plastic).
Your car will run 10 degrees cooler just by this mod alone.
Old Jul 19, 2002 | 09:10 AM
ivelweyz
What the **** is that supposed to mean? I didn't know we had prejudice ***gots on the org.
Old Jul 19, 2002 | 09:24 AM
Axra's Avatar
The heat given off by the cap gets dissipated to the engine compartment. I recommend the Stillen Oil Cap Cooler (part# 69XXX69) on sale now for $627.
All piping and clamps are not included so you will have to order those as well.
Maybe we can start a GD.
maxprivate
Nov 29, 2017 08:52 AM
cheftoo
Aug 20, 2015 05:17 AM
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
