98 Maxima SE - "Service Engine Light" on
Old Jul 21, 2002 | 08:14 AM
cse98se's Avatar
About a month ago, the "Service Engine Soon" light came on, and using Haynes Repair Manual, the flash code was 0412 - Upstream oxygen sensor high voltage fault (right bank). After resetting the ECU serveral times, the "Service Engine Soon" light would come back on after approx. driving 300 miles in a week. I replaced both front oxygen sensors with Bosch ones and reset the SES light about a week ago.
Now I get two flash codes, 0412 and 0210 - Fuel injection system lean(left bank)
Does any know the correct repair for flash codes 0412 and 0210 ?
The 98 SE has approx 42,000 miles and seems to run fine.
Old Jul 21, 2002 | 09:46 AM
JustTry's Avatar
Re: 98 Maxima SE - "Service Engine Light" on
Sounds like a faulty O2 sensor, and or the harness and clips. Make sure you changed the correct O2 sensor (the RIGHT bank is more towards the back of the car on the Y pipe (not the cat). Also the second code should go away after the O2 sensor problem is fixed.
xUNIxPanther
Aug 27, 2015 10:09 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Flores94
Aug 11, 2015 12:53 PM
julian888
Aug 6, 2015 04:39 AM
