Test Pipe CEL
Old Jul 22, 2002 | 02:18 AM
JDM4LIFE's Avatar
Test Pipe CEL
okay, for those of you who have this, what if anything did you do to avoid tripping the CEL? mine keeps giving me the same CEL of having way-off readings from there being no catylic converter what-so-ever. since i have the 98 (i can't remember which years are different), my last o2 sensor is right after the testpipe/cat area so it registers the problems. anyone know what i can do to get around this so my car doesn't think it's running off and throw the codes? thanks!
Old Jul 22, 2002 | 06:58 AM
mitch33x's Avatar
I have a WSP test pipe on order. I have a 97 with the rear O2 sensor after the cat. Much help would be appreciated to avoid a CEL
Old Jul 22, 2002 | 08:22 AM
BBaker025's Avatar
Can you give me a link to warpspeeds test pipe? I have scoured their website and cant find anything about the test pipe, just the rndom flo cat.
Old Jul 22, 2002 | 08:46 AM
mitch33x's Avatar
WSP's test pipe is not listed on their website. Its $27 with 02 instert hole, $25 without. Give them a call...
Old Jul 22, 2002 | 09:51 AM
JAY25's Avatar
I am suppose to be getting one. From what I know from another member here he says his CEL comes on at times and thats because of the test pipe. He also has a 98 like myself and the person that started this thread. I will post myself if I keep on getting it, btw thats something you may have to reset all the times.
Old Jul 22, 2002 | 10:20 AM
csnow's Avatar
I'll kill you. I mean it
Re: Test Pipe CEL
First I'd like to say that I am no where near an expert on the catalyst problem that you are talking about
I do have a custom test pipe 2.5 that replaced my cat converter.
My yellow service engine light is always on.
I ran the codes at my friends shop. Catalyst problem is the only code that shows up.
My friend is a licensed mechanic and licensed smog tech. He said running a straight pipe or custom test pipe is not a big problem, except for the fact that the light comes on and its not good for the enviroment.
The way he explained it to me: at high speeds the EGR releases vacuum pressure. He said the car will have less back pressure but more free flow (for the speed demon inside me). He said over time that the EGR will have more carbon build up. Custom Test Pipe = Use at your own risk.
As far as gas mileage is concerned I get less in the city. Not a big problem for me. I love chevron 91 here in So Cali.
my engine / exhaust mods include: PR CAI, UR UDP, Stillen Flywheel, ACT clutch, Stillen Y pipe 2.5, custom test pipe 2.5, Greddy Cat-back SP 2.5
Old Jul 22, 2002 | 10:39 AM
JDM4LIFE's Avatar
well, i have pretty much all the main boltons (obviously, by my sig). my problem with the CEL is that it only waits about half an hour at most driving time before it comes on. the thing is, i know the computer isn't going to let me run 100% to my car's capacity. it's getting the off code after the "cat", so i'm pretty sure that it might change a thing or two on it's own to compensate, would you guys think? that, and i'd like to be able to know if/when i get a CEL for something else. i didn't know if someone on here had it and had a way to bypass it. i'm sure if you had your ecu sent in for reprogramming, there's possibly a way around it. any input??
Old Jul 22, 2002 | 11:44 AM
sanjaya's Avatar
i have wsp test pipe too and like it.. i recomend get the one with o2 insert. and NO CEL light.
edit: i think you better email them at warpspeedperformance@direcpc.com for more info.
Old Jul 23, 2002 | 12:19 AM
JDM4LIFE's Avatar
what kind of o2 sensor hole are we talking about? the 2nd o2 sensor already has a place it's supposed to be at after the test pipe.
Old Jul 23, 2002 | 01:45 AM
TN-Max's Avatar
u guys have me worried now, i was about to order a test pipe because i dont have to go through any types of inspections where i live, but i certainly dont want the CEL on all the time, if someone finds out that its possible to fix this please post
Old Jul 23, 2002 | 08:28 AM
JDM4LIFE's Avatar
i figured out it's also giving me a bad egr code. so for right now i'm getting obd II codes P0400 and P0420. once again, anyone have input?
Old Jul 23, 2002 | 11:43 AM
JAY25's Avatar
I just got my in the mail so Ill post and inform what codes will I get!!!
Old Jul 23, 2002 | 11:55 AM
Cumalot's Avatar
I have the WSP test pipe installed on my '96. No problems so far.
Old Jul 23, 2002 | 12:42 PM
BrianV's Avatar
I got CEL light with mine, it's only obvious cause the reading of the rear O2 is going to have a lot more carbon and other crap in it.
I drove with a GForce ECU in my 97 for 4 months so I'm used to the yellow light.
Old Jul 23, 2002 | 01:46 PM
BBaker025's Avatar
Do I need a test pipe with O2 sensor hole for my 97 I30?
Old Jul 23, 2002 | 04:16 PM
BrianV's Avatar
No you need one without
Old Jul 23, 2002 | 10:04 PM
JDM4LIFE's Avatar
well, as far as the egr code, i'm going to (in the next few days) go through my egr system as much as i can and clean it out. i'm hoping that might be the suspect. i dunno what i'm gonna do about the rear o2 sensor....
Old Aug 23, 2002 | 10:48 AM
dashingMax's Avatar
Did any of you guys find a resolution to this? 3 days after the test pipe, I get the same P0420 code. I can buy a new O2 sensor & replace it, however, I'm afraid since there is no cat, it will come back AGAIN!!
Any help would be appreciated.
Old Aug 23, 2002 | 12:49 PM
dashingMax's Avatar
BUMP
Help Please !
Old Aug 23, 2002 | 06:03 PM
JDM4LIFE's Avatar
dashingmax, i know this is a little out there (i have the same cel still), but if you were to do something like an ecu upgrade, you could fix it. since we both have 97+, we would have to buy a 95-96 ecu anyways and send it to jim wolf. if we bought a 95 ecu to upgrade for our car, it'd be obd I.... another solution, a good friend of mine works at autozone. he says he knows you can get "dummy" o2 sensors that send a good signal no matter what. i think he said they're around $100.
Old Aug 25, 2002 | 02:02 PM
dashingMax's Avatar
Dummy O2 sensors! I've seen them & they're about $20.
Will try if the light comes back on!
Old Aug 25, 2002 | 03:10 PM
VQdriver's Avatar
brianV, does your CEL come on instantly with the older ECU in your 97 or does it take a few days? for all the others here who ask about the CEL in reguards to the test pipe: every 2 or 3 days i get a rear catalyst code and occasionally a high/low flow EGR code. i reset them whenever they come on. my car gets pretty good gas mileage with them. as for the long term side effects, that's unknown to me.
Old Aug 25, 2002 | 09:32 PM
dashingMax's Avatar
Any difference in performance?
Old Jul 7, 2005 | 08:44 AM
dss42's Avatar
I get P0400 code also on my 98 and i had the test pipe on there for about 1 year 1/2 what can i do to solve the problem? If I keep driving will I have problems?
Old Jul 7, 2005 | 09:15 AM
MaximaSE96's Avatar
Maxima Owner
of course if u have no cat ur gonna get a CEL light no matter where the las t02 sensor is...ur car is producing way to much hydrocarbons and the 02 sensor is picking that up and tripping ur CEL light...two ways around it....put a cat on because on an N/A CAR test pipes dont do shizit but make stinky and pollution.....or buy an 02 emulator kit from ebay
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
