put the rsb in tonight
Old Dec 11, 2000 | 06:26 PM
96BLUMAX's Avatar
It is so amazing. I think I like it better than my fstb. It smacks the back of the car into place. I was driving and no matter what I did the back would stay flat on the road. It only took me an hour to put it on and it isnt that hard. Just takes patients and it would probably take half the time if i had a lift. If you dont have one I highly recommend it. I also heard there is a group deal on one so check it out. Theres my little reaction to the rsb.
Old Dec 11, 2000 | 06:41 PM
chris j vurnis's Avatar
I have a Stillen bar. Is yours the same?
Try going up or down a driveway ramp at an angle
rather than straight on...
And then see how much you like the rear stabilizer bar...
If you hear no noises or metal to metal contacts, then the clearance of the bar running under the rear axle should be fine.
If you want to lower your car with coilovers or if you heavily load the rear end, you may have an issue with
the forward most clamp on the trailing arm contacting the undercarriage of the car...
jsmith24
Feb 1, 2016 12:35 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
