T3 garret turbo - anyone running it ?
Old Jul 29, 2002 | 09:39 AM
hlh0501's Avatar
I know its not the biggest turbo ever, just curious if anyone is running one, and/if they make enough boost to make it worth our time...
any details would be appreciated by the curious hlh - thansk in advance
Old Jul 29, 2002 | 09:54 AM
95emeraldgxe's Avatar
try nigels kit, it will probably save you money
Old Jul 29, 2002 | 10:05 AM
Jeff92se's Avatar
I'm needing a caw
How profound
Old Jul 29, 2002 | 11:09 AM
hlh0501's Avatar
who said anything about a kit? i was just wondering if a garret t3 is big enough to do anything?
Old Jul 29, 2002 | 12:12 PM
oh - i was just assuming that u wanted one for your car, thats why i suggested the easier route
Old Jul 29, 2002 | 12:29 PM
Canuck's Avatar
From what I understand a T3 would be too small as it would not be able to flow enough at high rpm for an engine with a displacement as high as ours. I am not positive on this so maybe one of the experts could help more.
Old Jul 29, 2002 | 12:33 PM
hlh0501's Avatar
this is the kind of response i was looking for ... hmmm, thanks - any experts to help out more? we have a good start...
i am looking into putting a T3 on right now, and i am not going to buy that kit... custom fab. i like t3's a lot, but if it isnt big enough i just need to know for sure one way or the other
Old Jul 29, 2002 | 12:38 PM
Canuck's Avatar
I think that a T3/T4 hybrid would work a lot better on a maxima. It spools faster than a T4 but flows more than a T3.
Old Jul 29, 2002 | 12:42 PM
Jeff92se's Avatar
I'm needing a caw
You are not descriptive enough. The T3 comes stock on some Z31 300zs(which are 3.0 liters) But they run only about 4-8 psi. So for low boost applications, it would be fine. But they get inefficent for higher boost(maybe 12psi+).
Old Jul 29, 2002 | 12:45 PM
Canuck's Avatar
So as long as they are being used for low boost it should work OK. Well I did say to wait to hear from and expert
Old Jul 29, 2002 | 12:49 PM
Jeff92se's Avatar
I'm needing a caw
Put it this way, A T3 felt pretty damned good to me(for the short time I was running one on my VE )
But considering Nigel's experiences, maybe a T3T4 would be a better choice. I went for a T3 for two reasons, cost and my 140,000 motor probably won't like what a T3/T4 is capable of.
Old Jul 29, 2002 | 12:52 PM
Canuck's Avatar
Nigel is actually running a TO4e, but he recomended a T3/T4 for a lower boost street application. I think Turbomax is running a t3/t4 but I am not sure. They are a lot more expensive than a TO4e, I now need to see if a T3 is less $$.
Old Jul 29, 2002 | 12:57 PM
SMX's Avatar
SMX
The T3 is at affordable price…for me anyway. Does that require a lot of fabrication also?
Old Jul 29, 2002 | 03:28 PM
ivelweyz
Don't the 300z's run sequential turbos or something? Don't know what it means actually, but to me it sounds like a small turbo for low-end and a bigger turbo for top-end. Once the small one starts to drop off the big boy kicks in. T3T4 is sosmething like this right?
Old Jul 29, 2002 | 03:30 PM
Jeff92se's Avatar
I'm needing a caw
Umm, to put it as lightly as I can, every one of your statements are pretty much not correct.
Canuck's Avatar
The T3 is used in the Z31 which is not the TT Z its the previous model.
The T3/T4 is a T4 housing with a T3 turbine.
Old Jul 29, 2002 | 03:33 PM
ivelweyz
I never said the TT Z ran T3's...
Old Jul 29, 2002 | 03:34 PM
Canuck's Avatar
Then what were you trying to contribute to the thread as it was unclear. The thread is about T3 turbos.
Old Jul 29, 2002 | 04:04 PM
Craig Mack's Avatar
All YOUR grammer belong to me
It is my understanding that the smaller the turbo the faster it will boost. Small turbo's will spool up really fast on our cars and give great punch around town, but will run out of breath in the higher power bands. The bigger turbo will allow more PSI but will take longer to spool. Ain't I right Jeffy?
Harold, who do you have in mind to make a custom turbo for you? Hell maybe we can bug Chaz enough to build you then me a kit for dirt cheap.
Old Jul 29, 2002 | 06:01 PM
ereet's Avatar
Doesn't the VQ30DET run a T3? I'm just going off stuff I've read in the past 48 hours, so I could be wrong. 6-7psi of boost if I remember correctly as well. Personally I'd want to go bigger but I still wouldn't be complaining with one
Old Jul 29, 2002 | 08:54 PM
ivelweyz
I just read the thing about the TT turbos a few days ago. I have no statements in my post. I said " What I think it means" I dodn't know **** about this crap that's why I always say that. What better way to learn than from all of u guys...
Old Jul 29, 2002 | 11:59 PM
Shadow's Avatar
TT Z's aren't sequential turbos either. They run 2 identical turbos. Supras and RX-7's (newer ones anyways) are sequential turbos.
Old Jul 30, 2002 | 01:46 AM
turbo97SE's Avatar
For off the line quick response, The T3/T4 is probably the turbo of choice. I wouldn't say the T3 is too small, providing you are running less than 5-6 psi.
In looking at my dyno graphs, my power drops off rapidly after 5200 rpm . This is a characteristic of our intakes\ runners on the 4th gens. A T3/T4 would be a good choice to produce power over a broader rpm range - starting earlier. You do lose top end power, but you lose it anyway because of the intake runners ... how much worse for T3? .. I don't know. I am hoping to get a VI in the not-too-distant future and get that top end back! I would love for someone to try the T3/T4 with the kit to show performance differences. too bad I don't have the money to buy another turbo to try this. Actually lag is not bad at all for the T4 if you drop the clutch at a higher rpm 2500 to 3000 rpm. I really can't complain too much about the T4. Too much response at the low end just causes you to spin the wheels and not go anywhere. I can spin with the T4, might be a problem with the T3/T4.
As for sequential turbos, Supras and RX-7s are the more popular cars. The rest are just regular twins. Maybe next year, I will look into sequentials as a project. It's actually a pretty simple concept really. Boost control would be a little tricky though.
Old Jul 30, 2002 | 11:56 AM
ivelweyz
Thanx for not being a ****er...
Old Jul 30, 2002 | 12:18 PM
Canuck's Avatar
Old Jul 30, 2002 | 12:22 PM
Jeff92se's Avatar
I'm needing a caw
No problem
Old Jul 30, 2002 | 12:54 PM
nadir_s's Avatar
vicodin ... gift of life
How much do T3's cost (plus installation)... an estimate please?
Old Jul 30, 2002 | 01:00 PM
hlh0501's Avatar
T3 is 200+ (ebay) or 700new... then you need an intercooler, plus you have to have vortech or other brand fmu/fpr... you need a shop to custom fab the flanges off your exhaust manifolds and custom bend it all around to get it up front ($$$), and then get the exhaust back out is a pain too b/c of size restrictions down there - plus all the intercooler piping. Then with a T3 you need both oil in and out and water in and out, so you must tap the oil supply both directions (harder then you would guess) and the water is easy off the heater cooler.
Then your going to want a bunch more stuff, including larger turbo - (guages, boost control maybe, pump, etc... )
the biggest $ is probably going to be labor/piping ... its nuts , but i cant give an estimate.
oh yeah, and shops hate this idea for some reason (besides performance car shops, and still 1/2 of them hate it)
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
A32goldylocks
Sep 14, 2015 06:49 PM
ballerchris510
Sep 10, 2015 09:35 PM
