Installing Air/Fuel Gauge..... few questions
Old Jul 31, 2002 | 08:41 AM
ny96max's Avatar
Im gonna be buying an air/fuel gauge from Autometer. I know how to power the thing up illumination wise and power wise. But wich sensor under the hood do i tap into to get the correct readings from??
I was told a while back there is a two small harness right in front of the valve cover and that i tap one of those wires?? If you know where to go for this lead please post.
thanks guys!
Ant
Old Jul 31, 2002 | 08:47 AM
mtrai760's Avatar
'Trynna' is not a word
Their is a blue and white stripped wire, with extra shielding around it, it goes into the O2 sensor connector at the front right of your engine, that's what you tap into...
Old Jul 31, 2002 | 09:01 AM
ny96max's Avatar
wow that was a fast response!!
i just looked at that plug on my motor, i have a red/black stripe a blue and a white. They do go into an o2 harness that goes down to the sensor.
anyone with a 95/96 max??
Ant
Old Jul 31, 2002 | 09:15 AM
Chunger's Avatar
My other car is a Hybrid
http://www.autometer.com/hp/instruct...tions/837j.pdf
http://home.earthlink.net/~msue2/_images/ecuO2.jpg
Old Jul 31, 2002 | 09:34 AM
ny96max's Avatar
thanks Chunger!!!
anyone else have advice??
Ant
Old Jul 31, 2002 | 11:13 AM
WizzaMax's Avatar
Don't tap into the shielded wires...they are actually on the 02 sensor...use the ones just at the front of the bank on the plug.
Old Jul 31, 2002 | 11:18 AM
95emeraldgxe's Avatar
this is OT..........i like your car wizza!!!!
Old Jul 31, 2002 | 11:27 AM
SmoothMax's Avatar
OG
Tap into the white wire. That should be the middle of the 3 that you indicated below.
Ant
Old Jul 31, 2002 | 11:52 AM
MaxSpeedSE's Avatar
E-mail SX7R he can send you a picture of the ECU and what wires your need to tap into, take your time, i bought my guages and guage pod for a great deal and was all exsited but couldent get mine to work, so i ended up selling them
Old Jul 31, 2002 | 11:57 AM
MaxSpeedSE's Avatar
Wait i still have a copy of the pic, here is your ecu and the red circles are the ones u have to tap into
-ChRi§
ECU
Old Jul 31, 2002 | 12:46 PM
ny96max's Avatar
do i tap into both of those wires indicated $50-#51?? or just one of the two??
I might try that white wire on the harness i was looking at earlier and see if that will give me anything 1st. Id rather not tap into wires off my ECU, hehe.
OT: I got my Autometer Phantom gauges(AF,Volt,Dual-pod) shipped for $120 through a friend who has accounts with distributors in Cali.
thanks for all the help so far guys!!!
Ant
Old Jul 31, 2002 | 02:22 PM
sx7r's Avatar
tap either 50 or 51, but not both. one is the front bank and one is the rear bank.
Old Jul 31, 2002 | 02:58 PM
ny96max's Avatar
thanks for clearing that up
Ant
Old Jul 31, 2002 | 03:05 PM
oCtoG3's Avatar
i'd have to agree with this,.. after puttin nitrous and feelin the need for gauges i did the same thing and my AF gauge never read right, it always stayed in 1/2 in stoich and 1/2 in lean and whenever my Rockford amp dropped real low the thing jumped all the way to the last led light on the rich side if you read those instructions from Autometer, at the bottom it says something about doing damage to the gauge if you tap the wrong wire or tap it at the wrong place or something like that.
Old Jul 31, 2002 | 03:10 PM
sx7r's Avatar
the autometer A/F gauges aren't very accurate to begin with. i used to have one and when i was running lean it'd still light up all the green leds. so i sold it and got different A/F gauge.
Old Jul 31, 2002 | 07:37 PM
ny96max's Avatar
im really getting it for the "sporty look" and to finish off my interior modding So if its not that accurate it wont matter.
Ant
Old Jul 31, 2002 | 08:27 PM
Cumalot's Avatar
Awww Antony, I could have sold you mine for a very cheap price. If only I have known. I got an Autometer Air/Fuel gauge, but not going to use it because I'm going to use the EGT gauge instead. Oh well.
Old Jul 31, 2002 | 08:32 PM
ny96max's Avatar
damn you mike...... j/k
Ant
Old Jul 31, 2002 | 09:53 PM
Confused's Avatar
Permanent Maxima.org Resident
hook it up to the stereo
Ant
Old Jul 31, 2002 | 11:01 PM
98fiveSpeed's Avatar
off topic,.. but since the o2 sensor simply sends a voltage based on the oxygen content of the exhaust. 0.45 V means u are running at 14.7:1 afr and anything less than .45 means ur running lean and anything greater than .45 means ur running rich. Now my question here is that cant we simply make a Analog to Digital converter that would monitor this (and possibly other sensors such as EGR Temp and IAT )and then display that on a small 2X16 LCD which can be mounted anywhere thereby making those big *** guages useless... anybody follow me on this? has this been attempted? Im kinda curios.. I might try this out as a next lil project..
Old Aug 1, 2002 | 06:23 AM
oCtoG3's Avatar
hey are those Falken Ziex on ur car?...
if so how do u like em?
Old Aug 1, 2002 | 09:36 AM
ny96max's Avatar
it could move to my BASS.....
Ant
Old Aug 1, 2002 | 09:58 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've got them last April and they're a bit noisy. Having the radio on does wonders!
Old Aug 1, 2002 | 10:41 AM
No...I have Pirelli Pzero 245.40.ZR.18 in the back and Nitto 555's up front...Nittos were about half the cost of Pirellis....I love Pirelli but they wear out way to fast.. Nittos I dont know about. Ever since Ive put them on, my car feels as if its floating...but that most likly is due to my struts.. ****ing tokico's need replacement.
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
