Alloy vs. Steelies - Weight Difference?
Old Jul 31, 2002 | 05:50 PM
Rickalodeon's Avatar
Does anyone know what the weight of the steel rims are? And the weight of the alloys ('97 5-spoke)?
Thanks.
Old Jul 31, 2002 | 05:53 PM
95emeraldgxe's Avatar
Re: Alloy vs. Steelies - Weight Difference?
Thanks.
the 97 SE rims weigh 19.6 lbs according to wheelweights.net
Old Jul 31, 2002 | 06:12 PM
dashingMax's Avatar
Re: Re: Alloy vs. Steelies - Weight Difference?
Hmm...
I weighed the rim with the stock tire on it, & it was exactly 40 lbs.
Does the tire alone weigh 20 lbs?!!
Old Jul 31, 2002 | 06:18 PM
sil SE's Avatar
Re: Re: Re: Alloy vs. Steelies - Weight Difference?
i thought ericdwong posted that he weighed his at 45 or something. oh but he said his tire was heavy i guess.
Originally posted by dashingMax
Hmm...
Old Jul 31, 2002 | 07:02 PM
Hmm...
Old Jul 31, 2002 | 07:50 PM
So the consensus seems to be that the alloy is about 20 lbs. How about the steel rim?
dashingmax...Does the 40 lbs. include the steelie or alloy? Wasn't sure if you were referring to stock SE. If referring to a steelie, does anyone know what a tire weighs? I'll do the math.
Thanks.
Old Jul 31, 2002 | 10:43 PM
syc's Avatar
syc
Thanks.
steels are also about 20 lbs each.
Old Aug 1, 2002 | 06:31 AM
Sounds like there's no difference in weight between the steel rims and alloy.
Thanks for the info folks.
Old Aug 1, 2002 | 08:34 AM
dashingMax's Avatar
The stock 5-spoke alloys are also 19.6 lbs...I guess.
Hmm...
Old Aug 1, 2002 | 09:35 AM
dgeesaman's Avatar
Maintenance Monster
Hmm...
It certainly does. Hence one reason for tire shaving.
Dave
Old Aug 1, 2002 | 10:34 AM
Str8ridin's Avatar
Wrong, big difference. Although they may weigh the same, the 16inch alloy is much heavier (rotational wise) than the 15inch steelie.
Old Aug 1, 2002 | 10:45 AM
Interesting observation. Do you mean that most of the weight is distributed to the circumference of the wheel rather than the center?...or are you describing the difference between a 15 and 16 inch wheel?
Either way, is there a noteable difference in ride performance?
Thanks.
Old Aug 1, 2002 | 10:54 AM
Str8ridin's Avatar
Thanks.
You got it...I was reffering to increased rotaional inertia due to the distribution of the wheels mass in relation to the distance from the center of the wheel from the eddge. As far as handling performance, a larger diameter rim will yeild crisper cornering and more precise handling (if combined with the proper size tire). Acceleration wise, between a 15 and 16 inch, accelaration AND braking will be effected, but not as dramatic as a 15inch to 18inch upgrade.
Old Aug 1, 2002 | 12:06 PM
dashingMax's Avatar
Hey Raceen, how much HP do you think is lost when going from 16" steel wheels to 16" alloys to 18" alloys?! Just a rough estimate will do.
Old Aug 1, 2002 | 12:15 PM
Str8ridin's Avatar
I beleive from 16" alloys to 18", using average wheel weights, around 2-5 max hp. Again, that's using average wheel weights. The numbers grow exponentiaily when you start getting into the 22" - 24" SUV rims!!!
Old Aug 1, 2002 | 12:19 PM
NYCe MaXiMa's Avatar
Steelies with tires and no hub caps weigh around 41 lbs each.
I just sold a set and I put 2 wheels and tires into each box. The weight came up to like 82.X lbs for that box. That is around 41 per wheel and tire.
My 2001 16" wheels weigh exactly 20 lbs each without the tire.
Old Aug 3, 2002 | 10:03 PM
dko's Avatar
dko
duck and cover
dammmmmmn! your car looks gorgeous man. i remember when you called me about where to get a Y-pipe installed... now you've got an S/C. props on the car... if you don't remember me, I'm dan from the old orchard meet.
Old Aug 3, 2002 | 10:30 PM
iregula's Avatar
a lot
Old Aug 4, 2002 | 02:09 PM
dashingMax's Avatar
Hey Dan, of course I remember you. How you been?
Yep, I went all the way...got it supercharged! :-)
Greddy cat-back is on its way!
Old Aug 5, 2002 | 08:52 AM
dko's Avatar
dko
duck and cover
damn, man. i've been good. not much moddin, tho. just strut/sway/franken car (on the way) and the SFC's. when's the next meet? I wanna see your car. 2kAE's car was super phat too!
user 11122324
42
Jul 18, 2022 03:35 PM
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
