Unhappy Electrical...
Old Aug 2, 2002 | 10:56 PM
on_alert's Avatar
Well, Im new to this forum, and ive already managed to blow out something electrical in the max... I put a different wiring harness on the side marker lights and put in a 55 watt halogen bulb...) I turned on the lights and heard something sizzle in the fuse box area and then the light died. Now my tails, sidemarkers, & clearance lights dont work... Basically, everything that is connected to the parking light circuit...
Like i said the fuse in the engine bay is fine
(is there another fuse/fusebox lurking mysteriously around, possibly in the cabin of the car? )
Any Help would be greatly appreciated... Thanks Guys. Hope to be posting alot...
(PS: What is the best HAI, and which is a better Y pipe, WSP or budget... just kidding)
Old Aug 2, 2002 | 11:02 PM
jmax
Above your left knee, actually, a little to the left of.
Old Aug 2, 2002 | 11:03 PM
nadir_s's Avatar
vicodin ... gift of life
Re: Unhappy Electrical...
yes, there's another fuse i believe marked for "taillight" ?? It's in the fuse thingy next to ure steering wheel (left under)
Old Aug 2, 2002 | 11:11 PM
on_alert's Avatar
Hey there it was glaring me in the face...
Popped it open, theres the blown fuse. Kinda feel like an idiot though for not seeing it myself... i mean, come in its in the d a m n owners manuall.
Thanks Guys
Also: How can i find out what type of fuse to put in there. Im planning on putting a 55 watt halogen bulb in the blinkers and the sidemarkers. Trial and error? Think it'll melt the lens? Im willing to find out...
I also plan on modifying the blinkers so they are on all the time and flash on and off when actuated (not bright and dim)
Old Aug 2, 2002 | 11:30 PM
jmax
Re: Hey there it was glaring me in the face...
Thanks Guys
Is 55 watts the consumptin or output? Most likely comsumtion. I thought stock bulbs were 55 watts, aftermarket 110 watts. Sorry, you said blinkers. Check the faqs to see if you will exceed the wiring limits of the bulbs. Otherwize, 55 X 2 for two bulbs is 110 watts. Divided by 12 volts is a hair under 10 amps. So if you are blowing a 10 amp fuse already, there is a problem in the wiring. Thinner wiring gets hotter than heavy wire. A matter of resistance. So thicker, heavier gauge wire will transmit power more easilly, and with less resistance.
Old Aug 3, 2002 | 08:59 AM
Chunger's Avatar
My other car is a Hybrid
Thanks Guys
Stick with stock...
Old Aug 3, 2002 | 09:04 AM
jmax
Check the lighting section in the Faq's. I don't know what gauge wire nissan used for the lights. That will most likely be your limiting factor when deciding if you can upgrade the fuse to a higher amperage.
Old Aug 3, 2002 | 12:59 PM
Requin6's Avatar
Re: Re: Hey there it was glaring me in the face...
Originally posted by Chunger
Stick with stock...
thanks chunger, you just answered my question and i didnt even have to ask! on the back of my fuse plate, the fuse map isnt there. finally found it
melteye
May 16, 2016 12:02 AM
1BADMAX
74
Dec 3, 2003 06:42 AM
BBaker025
May 18, 2002 09:49 PM
ajahearn
Mar 29, 2002 02:11 PM
