What wire to tap into to run Harlan RPM Switch for VI
I plan on running it off the coilpack. Should I just splice into it right at the coilpack wiring harness or what? This won't have an adverse effect on the performance of the coilpack for that cylinder? Which of the wires should I splice into?
Re: What wire to tap into to run Harlan RPM Switch for VI
Yeah, just pick a coil pack and tap into the wire that is striped (it is NOT the red or the black wire)...see pic below. I used those common tappers that you can find at Radio Shack or Home Depot. Should be safe--cuts the jacket but not the copper wire. I wrapped the splice with electrical tape and then zip-tied the end to prevent it from getting pulled out in the event of a tug.
Edit: tap not 'splice'
Wire taps are good if you leave the existing wire (no cutting), but if you do cut I would NOT recommend using connectors especially on something as important as a coil pack. If you decide to cut the wire at least solder and heat shrink your work. Like Carleton said tap the wire that's not 12v (red) or ground (black).
-hype
-hype
Originally posted by iansw
Or you can buy an actual wire tap at radioshack. Much more permanent, and much safer.
IanS
IanS
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
