How To Remove Super Glue???
Old Aug 7, 2002 | 12:22 AM
krzymax's Avatar
Maxima owner since 2000
I have some super glue stuck on my dash and am wondering if there is any way to remove the super glue without hurting the fabric? thanks guys.
Old Aug 7, 2002 | 12:32 AM
Nismo's Avatar
I heard acetone (acetone nail pollish remover) works good with superglue
Old Aug 7, 2002 | 02:02 AM
JsL's Avatar
JsL
Acetone eats through a lot of stuff...test it out first before u try it. Don't be known as the maxima guy with a hole in his dash...
Old Aug 7, 2002 | 05:34 AM
pblaze's Avatar
Re: How To Remove Super Glue???
The best thing to do would be to go to the manufacturer's website and look for advice. Super glues (cyanoacrylates) have their lowest strength in peel, as opposed to shear and tension. They're also sensitive to heat and cold and mildly effected by water. Try this: put an ice cube in a zip lock bag and hold it on the glue. The object is to get it as cold as possible while still keeping it dry. Then try to gently scrape it off. If that doesn't work, try wiping it off with hot water and a little mild soap. Acetone is an absolute last resort because it will melt your dash instantly. If you could place a very small drop directly on the glue without hitting the dash, you may soften it enough to get it off with the hot water. If all else fails, slap a sticker on it
Old Aug 7, 2002 | 05:46 AM
Albertt's Avatar
Look at the bottle of superglue >>>
If it is cyanoacrylate based...go to your local hobby shop and ask for CA debonder/remover...it'll smell better and should work better than acetone.
Old Aug 7, 2002 | 08:15 AM
krzymax's Avatar
thank you to all the guys who replied and emailed me with advice.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
jaydot901
Sep 29, 2015 01:18 PM
