Auto Transmission question
I have a 95 Maxima GLE with 113,000 miles. Lately I have started feeling the transmission shifting, specially going from 1st to 2nd gear. Previously I had always admired the smooth shifting.
Is it something to worry about? What can I do about it?
Any advice would be appreciated.
SK
SK
Originally posted by MONTE 01&97 SE
4th gen autos dont shift to smoothly to me, at least mine doesnt since day one from 1st to second even when they have new tranny oil.
Originally posted by DTR Maxima
mine doesnt really jerk forward, but it isnt really all that smooth. its more of a lunge forward, but i dont mind it much
Same with mine!
Same with mine!
Same here. Its not the tranny fluid. It only shifts hard on low RPM's. If I go past 3000 RPM, it shift smoothly. I got used to it and its not that bad.
Engine/Exhaust
HKS HAI
UR Underdrive Pulley
Stillen Y-Pipe
Tunable Bomb (E-Bay Exhaust)
Fuel Preasure Regulator
2.5 inch catback
High Flow Cat
Suspention
Tokico Blues
Eibach Pro-Kit
FSTB
Addco RSB
Mods That Give Me the MOST HP
Chrome Blue Window washer LED's +10 Hp
Carbon Fiber Dash Trim +3 Hp
Tinted Windows +2 Hp
Trenz Grille +15 Hp
Diamond Cut Clear Corners +10 Hp each
Clear/Red Taillights +20 Hp
and some rims I got off Hoon.
Engine/Exhaust
HKS HAI
Stillen Y-Pipe
2.5 inch catback
High Flow Cat
Suspention
Tokico Blues
Eibach Pro-Kit
FSTB
Addco RSB
Trenz Grille +15 Hp
Common...
It seems it is common to most 4th gens. Lurch forward in the morning and then buttery smooth when warm. Has anyone experienced this with normal tranny fluid and found it gone when going to Redline synthetic?
Re: Common...
Re: Re: Common...
Originally posted by Chino
Who makes redline synthetic? I might try it....thats when I figure what the fuild capacity is!
Re: Re: Common...
drain/fill
Or, buy 5 feet 3/8"ID (I think) clear hose($2) at HomeDepot/Lowes/Plumbingsupply....
Connect(use hose clamp) to either A)the pressure line from transmission(see ATF COOLER FAQ) or B)connect to transcooler exit point(flushes cooler).
Drain/refill transmission(~4.5 quarts).
Overfill by 4 quarts(optional) and start motor. Dirty ATF will be pumped out of clear hose into container of your choice. Do not let ATF pump run dry(it will gurgle/burp/bubble before running dry). Always monitor fluid level in container. Stop before the amount that exits is greater than amount used. And, if fluid is not clean, add ~4 more quarts and redo. You will see the fluid in the hose change color(means you are done).
Best if you have 2nd person(to yell at) in car(to shut off engine when container hits the 4 quart mark) with key while you hold the hose(don't hit neighbor's house with ATF).
This will flush your torque converter. The new fluid will displace the old fluid just like the flush machine. And it will save you money because you are not wasting new fluid(drain/refill method).
The total capacity of the transmission is 10 qts. I recommend having at least 12 qts. on hand to ensure you have enough to completely flush it out.
[self serving plug] Redline is a great synthetic ATF, but Amsoil synthetic ATF is the leader in wear protection and price, as well as being capable of longer drain intervals. Discounts Available.[/self serving plug]
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
boomerbrian
Sep 2, 2015 03:46 PM
