Indiglo Needles?
Old Aug 9, 2002 | 06:08 PM
MAXXspeed18's Avatar
Indiglo Needles?
does anyone know where i can buy indiglo needles besides on ebay, for some reason i don't trust the ones on ebay, its always the same guy selling them and all he wants to be paid with is BidPay, lol, i can't really see how fast i'm going at night bcuz i have reverse indiglos on
Old Aug 9, 2002 | 06:31 PM
SLC I30t's Avatar
Re: Indiglo Needles?
www.importintelligence.com or some spelling of that. Import Intelligence dot com. They don't work on 98 or newer. Well the do but you have to remove the red coloring from the back of you needles.
Old Aug 9, 2002 | 09:14 PM
BippuBenji's Avatar
Hmm, don't know anywhere else besides eBay. A good alternative are led bulbs that replace your factory 194 bulbs in your gauge cluster. I did read someones post and see a pic of how they looked with blue led bulbs. Pretty much the same as the needle kit. If you happen to have the clear needles (I think 95-97 non-SE) I recommend the "extra brightness" blue ones in the following link.
http://209.87.151.155/search_results...l=2&subcat=458
Old Aug 9, 2002 | 09:21 PM
SLC I30t's Avatar
Well the nice thing about the inteliglow needles are that you can 2 things differently...
1. Needles that are not the same color as your numbers...ex.white numbers blue or red or green needles.
2. Reverse indiglos are known to swell because of the heat produced from the 194's at night. So you can just turn on your R. Indiglo's and your needles and not worry about your dash lights warping your gauge faces.
Old Aug 9, 2002 | 09:30 PM
BippuBenji's Avatar
I didn't know that, good looking out, I then take back my adivce about blue led bulbs with aftermarket gauge faces.
Old Aug 9, 2002 | 10:12 PM
Since you got indiglo needles, i was wondering if they give you a whole needle and everthing needed to set it up, beacause as we were instaling the reverse gagues, i think my RPM gague f*** up and it idles at like 1000 RPM instead of like 700 RPM, i checked to see if the needles were rubbing against the gauge but that wasn't the case, they seemed to be messed up internally, do you happen to know howo to fix it?
Old Aug 9, 2002 | 10:16 PM
BippuBenji's Avatar
The needle kit are basically tiny led rings that go under the center of each factory needle. There are 2 write-ups in the how section of maxmadriver.com that talks about needle removing as well as sticking needles. Look for the How2 installed indiglo gauges and How2 install colored dash gauges.
Old Aug 10, 2002 | 04:49 AM
SLC I30t's Avatar
indiglo needle installation
You can follow these directions to recalibrate your RPM needle... But aside from below, rather than removing your needle completely, just turn the needle (after the needle rest has been removed). a little bit counter clockwise maybe the distance of 1000rpms to 700rpms. then reattach the needle rest and your done. But before doing that I would rev the car to the REV limiter and see if it dips up into reline. if it doesn't then the car is just idling higher because of the electrical load...stereo/AC/etc.etc.
Assuming that you have the bezel out of the car and the clear lexan cover off the guage pod... I reccomend doing this when you car is low on gas prefferably empty with the light on. If you just filled up thats ok too, but I'll explain later.
Start with the water temp gauge, just because thats the least accurate gauge.
1. rotate the needle gently to the top of the gauge with your finger (you should feel no resistance). Take a pair of needle nose pliers or hobby pliers and squeeze the bottom of the needle rest so it pops out.
2. remove the small screw from the gauge face
3. let the needle return to its normal position.
4. Counterclockwise rotate the needle to its calibration point. (this is when you will feel obvious resistance while turning the needle in a counterclockwise motion) while at this stop point or calibration point, mark its position on the white tub that the gauges sit in. THIS IS VERY IMPORTANT IT RELATES TO ACCURACY OF THE NEEDLES AFTERWARDS. After the EXACT position has been market continue to turn counter clock wise 2 full turns and on the second turn start to apply upward tension and continue to take the needle off slowly. its ok to turn the needle 7 or 8 times counter clockwise while doing this, the needle sits on the spindle with out any kind of screw threads. So continue to spin the needle with slight upward tension till if gently falls off the spindle.
5. Now that the needle is off, you can take the gauge off and apply the LED rings to clear plastic below the gauge. Be sure to have the actual LED's facing in the proper alignment. meaning that the 2 smaller gauges have the led light pointing towards the center and the 2 larger gauges will have the 3 LED's pointing towards the top of the gauges.
6. Place the guage face back on to/and over the LED ring.
** If you do not have white needles you will need to sand the red backing to the needles off and paint them white or a corresponding color to what ever color of indiglo needles you are installing. If you are a GXE/GLE and are also installing white gauge faces or indigle faces, paint the back side of the tips of your needles Red or blue so you can see your needles during the day. In some cases you'll have white needles on a glossy white guage face **
7. Make sure that the LED ring does not occlude the whole at all, this will cause your needles to stick and not move properly.
8. Place the small screw back in place on the gauge face securing it back on to the gauge pod.
9. In a counter clockwise motion-begin to turn the needles onto the spindle. this may take several turns. you don't want to apply too much pressure while turning or you break the spindle. as you are turning apply some downward force and you'll be done in no time. Besure to give your needle some clearance to turn. After you have the needle securly attached while still spining the needles Counterclockwise stop turning the needle at the calibration point. If you go to far turn it a full turn counterclockwise and return it to that point till you have it lined up exactly in the same spot you marked.
10. Gently move the calibrated needle clockwise to the top of the gauge you should feel it turn without it dragging on the guage face. You might let it go and let it fall using the internal spings in the mechanism, if it doesn't its ok. The smaller needles don't alway do this. reinsert the needle rest by pressing it into the whole with the needle resting above.
11. Continue the removal of needles the same way I have mentioned above.
*Note after you have all the needles done I recommend you cut a notch out of your white guage pod about the diameter of a pencil and attach the heavier wire into it, this will allow slack inside of the gauge and your thin coated wires to not chaff with driving road vibrations or accidentally being pulled on while installing the power source.*
Check and double check the clearance of the needles inside and outside of the holes so they don't stick or drag on the guage face.
I attached the power source to the cigarette lighter inside the dash because its an ignition powersource and there are only 2 wires leading to it so its easy to determine the hot and cold wires. If you refer to you directions they might indicate how to attach them to your dimmer switch for the interior lights.
Have fun, good luck..
James92SE
142
Jan 2, 2024 09:23 AM
captchaos
Mar 15, 2016 12:18 PM
Rage Maximus
Sep 3, 2015 12:26 PM
Justinmc760
Aug 23, 2015 03:10 AM
egali045
Aug 5, 2015 09:02 AM
