will these rims fit?
hey, I haven't actually bought my maxima yet, and I'm not too sure on the bolt pattern of the wheels. I am about to buy a set of wheels and was wondering if you guys could let me know if they will fit. (bolt pattern and tire size). Thanks in advance for your help.
17x7 Gunmetal with Polished Lip .
5x114.3 and 5x100 bolt pattern
BRAND NEW -Bridgestone Potenza RE040 - 215/45/17
thanks, -Jon
thanks, -Jon
Re: will these rims fit?
thanks, -Jon
thanks, -Jon
Make sure about the offset. Stock 4th gen uses 40mm offset. You should try and stay between 38 & 42 offset. You could get away with 35-45 offset, but you risk ruining your wheel bearings.
Good luck
Re: Re: will these rims fit?
Originally posted by dashingMax
The bolt pattern is correct. I agree that on a 7" wide rim, you should go with a 225 width tire.
Good luck
Good luck
Re: Re: Re: will these rims fit?
Originally posted by voltman
Actually, according to the manual, the stock offset is 45 with the alloys (15x6.5 and 16x6.5) and 40 with the steelies. (15x6)
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
