fuel ration to run 2.87 pulley on V2 s/c'r ???
Old Aug 24, 2002 | 08:07 AM
96bstdSE's Avatar
I'm currently running a 6:1 vortech fmu for the 3.125 pulley on the V2 s/c kit. I was wondering, if I upgraded to the 2.87 pulley will I need to change anything.... BTW, The car is controlled by the Apexi S-AFC controller.
Old Aug 24, 2002 | 10:34 AM
Nismo87SE's Avatar
Re: fuel ration to run 2.87 pulley on V2 s/c'r ???
Run 370cc injectors and use the S-AFC to control them.
Old Aug 24, 2002 | 02:52 PM
95nissanMax's Avatar
how much horse power/PSI will u have when u put in the 2.87 pulley
thanks in advance
Old Aug 24, 2002 | 04:35 PM
MardiGrasMax's Avatar
~12.5:1 AFR
Test and tune it on a dyno with a wide band O2 sensor to be sure you have it right.
My advice to you is an 8:1 FMU disc, it will be rich but you can lean it out with the AFC. This is the safest approach.
Old Aug 24, 2002 | 04:58 PM
Miasma's Avatar
doesnt the ecu adjust to the s-afc over time? negating the benifits of the s-afc?
Old Aug 25, 2002 | 10:14 AM
If you set it up properly, no.
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
ballerchris510
Sep 10, 2015 09:35 PM
