replacing OEM Bose speakers...
Old Aug 26, 2002 | 02:29 PM
maximised's Avatar
Hey guys, got a question that I haven't found an answer to yet...
I have a set of MB Quart 6.5 components (w/crossovers) that I would like to put in my car, but have been waiting on the dough to buy the new deck, amps, etc..
Can I use the factory Bose deck and just replace the door speakers with my Quarts? Do I need to use the crossovers?
Old Aug 26, 2002 | 03:58 PM
FLO_BOY's Avatar
Re: replacing OEM Bose speakers...
I'm an amatuer when it comes to these things...however, it's my understanding that the speakers themselves EACH have an amp...that is,
the deck does not have a built-in amp...SO, if you install the speakers
there will be almost no sound coming out of them...
FLO_BOY
Old Aug 26, 2002 | 04:57 PM
Miasma's Avatar
there are ways to hook up the bose HU to aftermarket speakers, I know you need a line level converter to start with, and i am pretty sure you still need an aftermarket amp.
i am about 90% sure that the stock amps are designed for 1ohm use and those MBQs are 4ohm which means that this amp will put about 5W max to those which will not even make them move a bit.
so, you will need to rewire the car, remove stock amps and speakers, install amps and i would recommend a decend headunit while you are at it, so... save those pennies...
6spd4dsc
May 9, 2022 12:30 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
Max139617
Aug 29, 2015 02:55 PM
