Window fell down!!!!!!!!!!! Please Help!!!
Old Aug 28, 2002 | 03:49 PM
UglyMax's Avatar
Ok. Well, my back window fell down and now won't roll down or up. And it is real easy to open just by pushing it down. 1)How do I take off the door panel? 2)What should I fix?
Please don't tell me to search. It is pretty urgent.
Old Aug 28, 2002 | 04:32 PM
mzmtg's Avatar
Minister of Silly Walks
The part you need is the window regulator assembly. List price is aound $75. Courtesy sells it for around $60.
My window is also permanently closed until I get one
Old Aug 28, 2002 | 07:17 PM
munji's Avatar
check it out first
alright pulling your door apart is a no brainer....just look for the plastic tabs connecting the innerdoor to the body....inspect
.....this happened to me and it ended up being that the small plastic peice holding the glass up broke.
>>>if this is the case
here's what i did, push the glass up into the up position ,then use glass adhesive and fasten the plastic peice back onto the glass, after fixing/replacing the plastic peice. Mine works fine now
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
