anyone know alot about the vq???
Old Aug 29, 2002 | 11:19 PM
chris_from_calg's Avatar
I have a 98 se and I've been shopping around for mods to do this winter. I think i want the JWT cams if they put out some alright numbers.(1100 $ is alot for cams). I've also been thinking about upgrading some other internals. I want to stay naturally aspirated because all the really fast maximas have sc or nos, and I want to be a fast N/A. One of the things I was thinking of doing is upgrading to higher compession pistons. If I was to do this would the valves be able to hold the increased cylender pressure? What do you think I should go compression wise? And my finall question, my engine has about 70 000 miles on it if I was to replace the pistons could I start using synthetic or is the engine to old end of story?
Any help would be greatly apreciated. Thanx Chris
Old Aug 29, 2002 | 11:27 PM
iansw's Avatar
Re: anyone know alot about the vq???
Most people who build their engine seem to import parts from the VQ30DET from Japan.
And I would think 70k is just when this engine is getting broken in. I've never heard of anyone having a VQ blow (unless they did something stupid/wrong) before 100k, even just using Dyno oil and such.
IanS
Old Aug 30, 2002 | 05:17 AM
mzmtg's Avatar
Minister of Silly Walks
Re: Re: anyone know alot about the vq???
IanS
the VQ30DET uses lower compression, about 9:1 if I remeber correctly. I'm sure that for enough $$, JWT could cook you up some 11:1 pistons and and ECU to go with them...
Old Aug 30, 2002 | 06:19 AM
rmb's Avatar
rmb
It's also not a chevy 350. Without something drastic like SC or TC you're not going to find a lot of "hidden" horsepower just by swapping cams and bumping compression.....
-RMB
Old Aug 30, 2002 | 05:46 PM
-RMB
the new topic is can I fit the vq30det into my maxima. anyone with any info please help.
Old Aug 30, 2002 | 05:52 PM
Nismo87SE's Avatar
All you questions can be answered by calling JWT or engine builders with lot of experience in Nissan engines. Also if you can't put up $4k for motor work don't even think about going hardcore NA. Custom pistons, install, motor work + cams aren't cheap. Judging from your post I bet you wouldn't be able to do the work so that adds around $1.5-3k in labor to assemble the motor.
Old Aug 30, 2002 | 06:09 PM
densetsu's Avatar
Re: Re: Re: anyone know alot about the vq???
here you go...
i fully understand if you were lazy and didnt want to search. i too would have done the same.
Old Aug 30, 2002 | 06:40 PM
Vyrus's Avatar
Re: Re: Re: Re: anyone know alot about the vq???
Originally posted by densetsu
here you go...
IIRC nobody actually has a DET in their Max. Rather the head portion of the block from the DET on their VQ30DE. Even Tilley. But I could be wrong.
-Cyrus
t6378tp
Sep 29, 2018 04:27 PM
Tmax78
Sep 25, 2015 09:07 PM
MaxRPM6
Sep 11, 2015 06:56 PM
ballerchris510
Sep 10, 2015 09:35 PM
