MaxSpeeds with GR2's
Old Sep 2, 2002 | 01:00 AM
djshawnee's Avatar
Hey guys, I wanted to know if the Maxspeed/GR2 combo would be the best for me. I want a drop, but I also want the smoothest ride possible. How do the GR2's compare to the AGX's in comfort level? Where are the best places to buy GR2's?
Also, between 17's and 18's, does rim size have anything to do with ride stiffness? What about between 15's and 17's?
Thanks for your help guys!
Shawn
Old Sep 2, 2002 | 09:18 AM
WizzaMax's Avatar
I can't see why there would be anything bad with running the MAxSpeeds and GR2...bear in mind they GR2 are meant for stock replacement...not performance oriented like others...so they will perform like stocks...but I and a lot of other members are running the springs with the stock suspension parts...and no complaints here...
if you got the car for smooth ride, there are some sacrifices you will make for larger wheels, more road noise and vibration transferred into the cabin ane the added price of larger diameter setup are the down sides.
Upsides are greater traction, better venting brakes, more aggressive stance and it just looks better depending on what style you have on now...Good luck and Happy Motoring!
Old Sep 2, 2002 | 10:35 AM
Nismo3112's Avatar
Custom User Title
How many miles do u have on the car?? and the pic in ur sig...is that the stance of the maxspeeds when fully settled? looks nice.
Old Sep 2, 2002 | 12:59 PM
WizzaMax's Avatar
Yes, that is my Max and the rims are sold waiting for new ones...
I have like 49k miles on it right now.
and thanks for the compliment
Old Sep 2, 2002 | 08:29 PM
djshawnee's Avatar
If the GR2's are meant to replace the stock parts, then won't they wear out faster than performance struts? From what I have been told, keeping the stock struts makes them wear out MUCH faster.
Old Sep 3, 2002 | 03:41 PM
djshawnee's Avatar
anyone?
Old Sep 3, 2002 | 08:41 PM
Vesaijan's Avatar
Originally posted by djshawnee
anyone?
This is a debatable issue currently...People have suggested that GR2's are nearly equivalent to, or surpassing, Tok blues in build/component quality. Apparently, GR2's should be able to handle drops up to 1.5 inches. Until someone does a comparo followed by a dissection of both shocks to inspect internal components, the world will never know.
RL
Old Sep 29, 2002 | 10:56 PM
co_maxima98's Avatar
Re: MaxSpeeds with GR2's
Shawn
Did you already get your Maxspeeds and GR-2's? If not, I'm having mine installed on Friday. I'll let everyone know how they turn out (although mine are going to be on the stock SE wheels).
Old Sep 29, 2002 | 11:22 PM
BippuBenji's Avatar
You should have no problems with the Maxspeed/GR-2 combo. It'll be a smooth perfect drop. I happen to have the Intrax/GR-2 drop without any problems for the past 1.5 years. My drop is much lower and I didn't have to sacrifice much ride comfort, so if mine is lower you should be much more in better shape.
Old Sep 30, 2002 | 07:34 AM
ZeRo MaX's Avatar
I made my mind.. i think i'm goin' with maxspeeds and GR2... but only if... the GR2 are better than stock and won't fail on me.. b/c i hear people saying that GR2s are stock replacements... will it help if i get the GR2 and maxspeeds over stock struts and maxspeeds?
Old Sep 30, 2002 | 08:33 AM
Everybody told me that I HAD TO at least get GR-2 or better to replace the stock struts, because the stock struts would wear out quickly. So they've got to be at least a little better than stock, I would think...
BkGreen97
Apr 2, 2016 05:47 AM
SuDZ
136
Feb 24, 2011 05:34 PM
96max
Apr 3, 2002 10:33 PM
theMax
Mar 18, 2002 08:41 PM
