Making a shift Light into sort of a window switch for NOS
Ok I am working on a small project for a friend. I am trying to convert his shift light to a Nitrous window switch. Using the diagram below what do yall think?
Any other suggestions?
I believe the purpose of a window switch is to turn on at a certain rpm and turn off at another set rpm. The shift light will work for turning on, but if he ever hits fuel cut he will have problems.
-hype
-hype
-hype
-hype
I think a real window switch will serve better, my buddy has one he isn't using 'cause he went to a turbo. I'll ask him how much he wants for it when I see him. Just give me an idea what your friend would pay.
He has one on order but we want to go to the track SAT
xhypex- your right the main purpose is on at a certain point off at a certain point.. to not go BOOM is the main idea
Guess I should has made it clearer what I want to do. I want the be able to turn the Nitrous solenoid OFF with the shift light.
He does not want to buy a switch, he has one coming..just wants to run his NOS at the track with out worring about the big bang theory
I don't believe you can accomplish what you want with the shift light. The shift light would work great for turning things on, but turning the solenoid off is another story. If you wire the 12V to the solenoid and to the relay in parallel, when the shift light activates, the solenoid will still be getting 12V. The only way to stop the 12V signal going to the solenoid would be to ground the signal (short circuit), but you would get sparks and lots of heat.
I would say wait for the rpm switch. You'll spend a decent amount of time and energy wiring this up for one night at the track only to take it off soon after.
-hype
-hype
-hype
-hype
Thanks for you help. I needed someone else to look at it.. I am not convinced that it can't be done.. I just can't see it.
Maybe a bacardi and coke will help.
thanks again
Originally posted by bags533
Yeah that is kind of what I thought. The diagram was the best I could come up with. If I had to turn something ON it would be simple, but turning something OFF with a GND is very difficult.. I found this out last night after about an hour
thanks again
thanks again
one side of the wire goes into pin 30 of the relay (SPDT), the other side goes into pin 87A of the relay
+12 to pin 85
ground output from shift light to pin 86
30 connects to 87A when it doesn't have + and -, then when you give it the ground signal, 30 will be connected to 87 which is open so you'll have no signal going to the solenoid on the + wire
Originally posted by «§»Craig B«§»
cut the power wire going to the solenoid
+12 to pin 85
+12 to pin 85
and it's my job
I thought 30 & 87 do NOT have continuity when the relay is OFF?
I should have just PM'd you..lol
Here's a relay
http://www.partsexpress.com/pe/pshow...Number=330-073
Here's the instructions
http://www.partsexpress.com/resources/relays.html
85 and 86 are the triggering 12V and ground (which can be reversed). Whenever a 12V (85) and ground (86) are provided, the potential difference makes the relay click and puts it in the energized state.
30 is your input voltage in this situation which feeds 87a (the nitrous solenoid) when the relay is at rest, and feeds 87 (which is empty) when the relay is energized.
When I installed my VI I used a Nissan 4pin relay, so I haven't had much experience with 5 pin relays. Now I know what that extra pin is for
-hype
Since we both just learned from Craig maybe we can help someone else
-hype
-hype
Thanks for helping get my head outta my butt
Owe you two.. craig just start a tab..it'll be simpler that way..lol
Now is there a possible problem having that voltage sitting there in the relay? Or since it will be short periods of time.. it is ok?
I used a 4 pin relay as well I thought that is what craig was refering to ..
pin 85 and 86 are the coil, pin 30 is normally connected to 87A, when the coil is energized, pin 30 connects to 87 and 87A is not connected to any thing
problem with what voltage? if you're talking about pin 85 +12 V source, just wire that to IGN power or something like that; the relay wont draw any current (well, very little) from it until you connect the ground and then it will go through the coil
I think he's asking about what happens to the 12V that goes to 87 after the relay is energized. It's an empty connection, but will the relay heat up?
-hype
-hype
if you are worried about it, wire the side of the cut wire going to the battery to pin 87A and the side going to the solenoid to pin 30
you could also do it that way if you need to switch the wire into the solenoid from + to ground by then wiring pin 87 to ground but I dont think you'd necessarily need that for this application
SPDT....again I did not read/see that.. I need to pay more attention to details
yeah..exactly what hype mentioned..just worried about frying the relay with the voltage sitting there..but I think your correct
But since you and hype helped me with all the info I just wanted to make sure I did not ruin much good information with a bad decision
thanks again guys
thanks again guys
Ok Bags and Craig, here is where we are at.
The 86 is constant power 12 volts, and the 85 is constant ground -. What do the other relay points plug into? Meaning what do the 30, 87, and 87a plug into on my nitrous setup?
Thanks......You two are a huge help.
cut the + wire so now you have 2 ends from that
one end of it goes to pin 30
one end of it goes to pin 87A
IGN 12V to pin 85
when car is on, pin 85 will have voltage but 86 will have no signal so pins 30 and 87A are connected
when the shift light comes on and gives the ground ouput, the relay will "turn on" which means it connects pin 30 to pin 87 (and not 87A) so this will stop power from going to your solenoid
hope this makes sense, if not, email me craigbrace@hotmail since I dont read 4th gen forums very often
and unfortunately I wont be able to make it to the track and meet this weekend. I'm back at school and playing on the GT club soccer team and we have 2 games at Clemson on Sunday
Ok, well I hope you do well this sunday
Maybe we can have a meet when you have a game..we can support ya
thanks for clearing it it again.. between that and what you wrote previously and the directions hype has maybe we can get erik's nitrous running.
have a good game and fun this sunday
thanks for clearing it ip again.. between that and what you wrote previously and the directions hype has maybe we can get erik's nitrous running.
Ok, awesome Craig, you are the pimp. Now, I can also plug the + of the shiftlight into the 87 pin so when the shift light ground is turned on, it switches over to pin 87 and turns on the actual lights to the shiftlight.
But your shift lights should be on anyway right?
Or do you not have them hooked up?
Re: erik and bags
Originally posted by nismo2020
how did it work out ?
erik has yet tel let me know. He is in school while I ***** the org...
You'll see the video from when we go to the track tomorrow.. BTW 100 mile trip one way..this should be fun
vingodine
45
May 21, 2016 12:46 PM
kjm900r
Aug 5, 2015 07:14 AM
