2nd (Replacement) Starter Failed After Only 9 months
Old Sep 11, 2002 | 10:51 AM
95gxe's Avatar
I had the normal grinding noise that others have experienced on cold starts with my Max. After trying everything else I finally had the starter replaced last Mid-December. The problem was solved. This morning the replacement starter failed as well. The car will not start without a jump now. The dash lights, headlights, and readio all work. So it is not the battery. I am wondering now if the problem is indeed the starter, or another underlying problem (maybe electrical) with the 95gxe. Does anyone have any insight? Or has anyone had the same experience? Please let me know.
Old Sep 11, 2002 | 12:01 PM
sinewave's Avatar
Just because your lights work don't think that your battery has to be good; it takes a lot of current to turn over the starter motor.
Clean the battery terminals and battery posts. It doesn't have to be covered with white crud to be corroded. Lead oxide is a very good insulator; clean the battery terminals with a wire brush until they are shiney. Also, check the water level of the battery and top off as necessary with distilled water.
If that doesn't work, take your battery out and have it tested at AutoZone.
Old Sep 11, 2002 | 12:06 PM
Scruit's Avatar
U wanna try me young boy?
I jump-star works, then your problem is insufficient voltage/cuurent. If the starter was bad then it wouldn't respond to a jumpstart, IMHO.
Maybe a bumpstart...
Old Sep 11, 2002 | 01:00 PM
Mishmosh's Avatar
I agree. Why would a jump-start help a bad starter? It probably wasn't fed enough juice. Definitely look into the possiblility of bad wiring (both ground and + leads) and a weak battery. Make sure the battery has enough fluid in each cell. You can also have it tested for free at Autozone.
Old Sep 11, 2002 | 03:17 PM
MIXXMAX's Avatar
Oh, my!!!! I just posted this particular problem last week! Look at my thread titled "Starter problem resolved!!!" I posted a couple of days ago.
Old Sep 11, 2002 | 05:20 PM
nadir_s's Avatar
vicodin ... gift of life
excellent advice... now go a step further. Check the wires that connects to the starter. Those may be corroded and need replacement. Just cehck the wires goin from battery -> ignition -> starter. I bet you anything you're problem lies there. good luck!
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
laparka66
Aug 6, 2015 09:36 AM
