Thicker head gasket to increase compression??
Old Sep 12, 2002 | 08:24 PM
MAXINXS's Avatar
I have wondered this for awhile and finally decided to ask. I have read in import magazines many times that thicker head gaskets are used to increase the compression of the engine, which then sometimes increases horsepower. I'm not sure if this would benefit more for cars with boost or n/a. Would this work for the Max?
Old Sep 12, 2002 | 08:32 PM
mzmtg's Avatar
Minister of Silly Walks
A thicker head gasket decreases the static compression of an engine.
This will lose HP on an NA engine.
Old Sep 12, 2002 | 08:55 PM
Sin's Avatar
Sin
I was thinking the same thing
I thought I misread him, and I thought about how increasing the compression ratio that way would not be a good idea on pump gas or on stock internals. With all the risks, and the fact that gains may not be had without much more work, I was just going to advise against.
Old Sep 12, 2002 | 09:01 PM
Keven97SE
Re: Thicker head gasket to increase compression??
Boosted cars can gain lots of HP with a thicker head gasket because the drop in compression allows them to turn up the boost more...and in the end, the HP they lose from the compression drop is well exceeded by the HP gain from the increased boost. They wouldn't be able to run that much boost normally because the engine would detonate.
Normally aspirated engines require an increase in compression to make more power. They don't have a compressor to shove in more air, so the more bang they get from the cylinders squeezing the mixture, the better...more bang comes from more compression.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxinout93
Oct 31, 2015 02:04 AM
jaydot901
Sep 29, 2015 01:18 PM
