Emissions Testing!!!!!!
Old Sep 16, 2002 | 02:39 PM
SeBlackMax97's Avatar
my car is due for emissions this month and im just a little worried that my car wont pass because of my y pipe. is there any helpful hints to make the car run cleaner or do i even have anything to worry about?
Old Sep 16, 2002 | 03:18 PM
MaximusMax's Avatar
Re: Emissions Testing!!!!!!
Just be sure to drive the car for about 25 minutes before you take it in. If all you have is the Y-Pipe, warm up the car, then bring it in. You'll be fine.
Old Sep 16, 2002 | 06:28 PM
giomontini's Avatar
Re: Re: Emissions Testing!!!!!!
Yep... that is true. A trusted mechanic once told me that never change your oil prior to emission testing and one of the reasons why you need to drive around for 25 minutes prior to test is that the car must burn excess oil from God-knows-where. Didn't asked for specifics and non were offered. I'm sure a lot of guys knew about this. You should be fine.
Old Sep 16, 2002 | 06:59 PM
JPMax's Avatar
What's next!?..
Yep, drive around for a bit to warm up the Cat and then take it to some local station that will do it right away and not let it sit for hours.
The catalytic converter works best when it's nice and hot.
Or so I hear..
Old Sep 16, 2002 | 10:22 PM
Nismo87SE's Avatar
Don't worry as long as the CEL isn't on or flashes an error code you will pass. All they do is the standard lighting, brake tests and plug the computer into the ECU to check the OBD-II for error codes. If you had an o2 simulator you could run a testpipe and still pass.
Old Sep 17, 2002 | 12:56 AM
darksands's Avatar
Yea, some places just do the OBD-II thing... Unfortunatley, I cant get rid of my CEL cause of my underdrive pulley sooo... I too the light out.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
