Just changed my fuel filter
Old Dec 18, 2000 | 10:45 PM
Kashoggio's Avatar
Changed my fuel filter today, what a pain in the ***. I thought it would take 10 minutes but it took like 45. Couldnt get my hands down there. Havent noticed a difference yet. Maybe mpg will inprove. Has anyone done this and noticed a difference?
Old Dec 19, 2000 | 06:08 AM
dwapenyi's Avatar
Feul filter change
You'll really notice it up top, especially winding out in 3rd, 4th and 5th gear. The car will be zingier up there.
DW
Old Dec 19, 2000 | 06:53 AM
Daniel B. Martin's Avatar
... Maybe mpg will inprove. ...
Sorry, but a clean fuel filter will not improve fuel economy.
Old Dec 19, 2000 | 10:13 AM
NickStam's Avatar
I don't see how changing the fuel filter will make a difference, unless if it has never been changed. I changed mine every 15k, the last time I looked, there was barely any dirt, or sediment, or whatever you wanna call it in the filter.
Old Dec 19, 2000 | 09:53 PM
SleeperSE's Avatar
Re: Feul filter change
[QUOTE]Originally posted by dwapenyi
[I]You'll really notice it up top, especially winding out in 3rd, 4th and 5th gear. The car will be zingier up there.
- Hey, nice word use there ("zingier"). How do you install the new filter and how many miles in between changes?
- Also, for a fuel injector cleaner, what brand would you recommend and what do you do with it? Do you pour in a whole bottle, how much fuel should be in the tank, etc.?
- Thanks guys! ;-)
Old Dec 20, 2000 | 06:21 AM
Kashoggio's Avatar
sleeperSe, its a pain, but its not hard. The filter is located on the fire wall behind the intake (sorta). Before you remove it you have to take out the fuel pump fuse out , and start the engine. After the engine stalls, try to start it. If it dosenty start, the fuel is cut off. ( I started the car about 5 times and it still has gas in the line) NOw for removing the filter, well just "simply" take of the hose clamps on the top and bottom of the filter and remove filter. And yes there will be some gas leaking. Now just install the filter, the hose with the clamps, and the fuel pump fuse. Now start your car, may want to pump the gas too. As for what brand filter? I got the only one they had at pepboys.
Old Dec 20, 2000 | 06:33 AM
AntGVR4's Avatar
DW
hmm... i don't know about this..
i doubt you'll FEEL any noticiable power difference..
i changed mine... didn't notice THAT much ..
Ant
Old Dec 20, 2000 | 06:53 AM
Re: Re: Feul filter change
Originally posted by Ant95se
... i doubt you'll FEEL any noticiable power difference..
A man who rejoices in a performance improvement after he changes his fuel filter is a man who had a clogged fuel filter.
Old Dec 20, 2000 | 08:26 AM
dwapenyi's Avatar
Re: Re: Re: Feul filter change
Exactly. The difference depends on how long your feul filter was in there before the change, and what type of gas you were using, whether its really clean or not. I changed mine for the 1st time at 33k miles. From the dramamtic change up top, I assume my filter was in there from the factory, hence, big improvement. Before the filter change that first time, my car couldn't get past 125 MPH. After, BINGO!
If you change the feul filter every 15K miles, you'll probably not notice as mmuch a change in performance, if at all.
Old Dec 20, 2000 | 08:39 AM
kratz74's Avatar
Hmm maybe after 100K miles I should change mine? I thought I felt a slight hesitation aroun 1800-2500 rpm maybe that's it?
Old Dec 20, 2000 | 09:14 AM
AntGVR4's Avatar
that might be a good idea..
100K miles .. yeah i'd say change it ..
i bought my car with 95K and changed it immediately ..
dunno how old it was tho .... still it's only a few bucks and will only help your car..
Ant
Old Dec 20, 2000 | 02:05 PM
dwapenyi's Avatar
fuel filter change
After 100 K Miles?? DEFINITELY change it.
But, before you do, take it for a top speed run and see how it does. Then, after you change the filter, do it again. It'll be like something woke up inside your engine. It'll probably fix that hesitation you mentioned as well.
Here's a testament from Steve Cutchen, he runs MaxFAQs. He changed his after 60K miles.
http://web2.airmail.net/scutchen/max_faq/
in the left pane, goto the maintenance section and choose CHANGING THE FEUL FILTER menu selection at the very bottom of the pop up menu.
The Wizard
24
Oct 1, 2015 08:47 PM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
