help! Do I have a coolant leak?
Old Sep 25, 2002 | 08:04 PM
arcenciel!'s Avatar
I hope you can help. 1 hour after I got home, under my car on the driveway was a puddle - odorless, colorless, and it seemed to be water - I'm guessing coolant. I traced it to be coming from above a horizontal black rubber boot connecting to the right front wheel. I felt to where the drip was continuing to come from, and it seemed to be coming from out of the end of a hose which points downwards, about 1 foot above this boot. The end of the hose is about 5/8". How serious is this and what is going on? Hope you can help!
Old Sep 25, 2002 | 08:26 PM
Toolrocks's Avatar
If it's colorless and odorless it's not coolant. Coolant is usually green, sometimes orangish but either way it has a sweet smell. IT sounds like it is more likely water. Were you running your a/c? IF so, it's probably just condensation dripping off the evaporator. Check the level of all your fluids to confirm none are leaking. Good luck.
Old Sep 25, 2002 | 08:53 PM
Dave Holmes's Avatar
Re: help! Do I have a coolant leak?
If your AC was on, don't sweat it (pun intended). From your description, it's a drain hose for the condensation from the AC. It is perfectly normal, and necessary. That hose is actually an often overlooked piece of preventative maintenance, as it needs to be clear so the condensation can drain. Good description of where it is at, as I had just checked mine last week to make sure it was clear (I had gone through some mud holes that caked my undercarriage). Hope this helps.
Dave
Old Sep 25, 2002 | 09:55 PM
arcenciel!'s Avatar
Yes, my coolant is green, and I did suspect this was water... but I haven't run my A/C for a couple of days. The nights are getting colder now that fall is here and I'm wondering if that has anything to do with it... ?
Old Sep 26, 2002 | 06:42 AM
iwannabmw's Avatar
Could be an exhaust leak too.
Old Sep 26, 2002 | 09:15 AM
dwapenyi's Avatar
The AC compressor automatically turns on if you use the defroster. Could have been that, too.
DW
Old Sep 26, 2002 | 12:32 PM
arcenciel!'s Avatar
DW
Yes I was uding the defroster... good idea.... so is that hose that i can reach up and feel a drainage hose?
Old Sep 26, 2002 | 12:48 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
It's water from your evaporator, no worry.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
