Will Greddy 60mm Warning Gauges fit in our Autometer Gauge Pods?
Old Sep 26, 2002 | 08:44 PM
Ramius83
I am interested in getting some gauges from Greddy since I plan on a big "project" in the future.....and I was wanting to get them while all Greddy items are 25% off. Now, I have seen many people use them with Maximas, but, will it fit in the Autometer Gauge pod? The reason I am asking is because I thought our gauge pod was a 52mm Pod? . Anyone know?
Old Sep 26, 2002 | 08:45 PM
Confused's Avatar
Permanent Maxima.org Resident
you have to dremel out a bigger hole in the pod. its not perfect but almost.
Old Sep 26, 2002 | 08:59 PM
Chunger's Avatar
My other car is a Hybrid
Many here have it dremeled out to fit a 60mm... For GReddy, Tomei, HKS, and...
Old Sep 27, 2002 | 03:43 AM
Ramius83
Thanks Chunger, that was very helpful. What exact gauges are those anyways? Thanks guy.
Old Sep 27, 2002 | 05:47 AM
Sprint's Avatar
Tomei i think has the best A/F gauge out right now.. its also very expensive.. i think its like $400 .. HKS makes the same type of gauges Greddy does.. boost, egt, fuel pressure and so on
Old Sep 27, 2002 | 06:27 AM
Confused's Avatar
non wide band o2 is BS no matter where you buy it. I'm trying to talk with tomei now.... get some good info.. get an EGT.
Old Sep 27, 2002 | 07:26 AM
Ramius83
For boosted Maximas, what are the two BEST gauges to have? I already have an EGT gauge and a FP gauge from Autometer that I have been using on my nitrous kit. Should I stick with these or get the better Greddy/Apexi/etc. gauges that have warnings/memory on them? Thanks guys.
Old Sep 27, 2002 | 08:59 AM
sx7r's Avatar
i've got a silver 60mm greddy A/F gauge for sale:
http://forums.maxima.org/showthread....postid=1410705
Old Sep 27, 2002 | 09:38 AM
Chunger's Avatar
OMORI with peak hold and warning lights... EGT and Coolant Temp.
Old Sep 27, 2002 | 10:11 AM
1FSTMAX's Avatar
How did you hook up the water temp gauge up? Did you tap into the stock sending unit?
Thanks!
Old Sep 27, 2002 | 01:08 PM
Synki's Avatar
Re: Will Greddy 60mm Warning Gauges fit in our Autometer Gauge Pods?
The gauge pod for the Maxima is for 52mm (2 1/16"). You can make the 60mm gauge fit with a little bit of dremeling.
Old Sep 27, 2002 | 01:10 PM
Chunger's Avatar
Thanks!
Old Sep 27, 2002 | 01:35 PM
1FSTMAX's Avatar
Did you get that adapter kit locally in SoCal? Or did you order it?
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
