Found yet ANOTHER ECU option for 4th gens--UNICHIP/Dastek in Australia
Old Oct 1, 2002 | 06:31 AM
Nealoc187's Avatar
SLOW
Here's the application guide on their site:
http://www.airpowersystems.com.au/un...lications.html
They don't have a dyno of the VQ on there, but they do have dynos of many other vehicles. I know manufacturer's dynos are always suspect, but its better than nothing. I wonder how these compare with Powerchip (Australian also) and the JWT, G-Force and JET Performance.
EDIT: I just realized it is a piggyback system, not a full reprogram like the others are. Kinda like the Apexi S-AFC and other systems. Sorry guys.
Old Oct 1, 2002 | 06:41 AM
redmaxpa007's Avatar
i SeE what you did therE
powerchip in australia has a chip for 95-99 maximas.. i been trying to talk to them about the 98-99 maximas specifically..
Old Oct 1, 2002 | 06:45 AM
Nealoc187's Avatar
SLOW
Yeah I know, I put it in my original post hehe. What have they said about 98-99. Not like I care since I have a 96 but I'm just wondering
Old Oct 1, 2002 | 06:49 AM
well, since there is not chip here for a 98-99 i want to make sure they have the correct ecu to modify aka chip
cause when installed my rev/speed meter i had to use a different ecu diagram than what apexi had listed for the max..
Old Oct 1, 2002 | 07:11 AM
Lime's Avatar
ooo. please can you get them to make one for $50? jk Let us know what you find out. I'm so sick of everything being for 95-97. I mean, we all know 99 is a toss-up with CA/fed emmissions, but c'mon...98 needs love!
Old Oct 1, 2002 | 07:48 AM
lp's Avatar
lp
I take it you've received the Maxima 'datasheet' from them.
http://www.powerchipgroup.com/gfx/da...ts/Nis0026.pdf
The engine pictured isn't exactly confidence inspiring, nor the lack of 'data'.
Old Oct 1, 2002 | 08:04 AM
yep..
i am trying to get a real person to e-mail back and forth
Old Oct 1, 2002 | 08:26 AM
erty67's Avatar
Decal Specialist
agreed!
Old Oct 1, 2002 | 09:27 AM
xHypex's Avatar
I really wish there was a chip available for '99s, but I would be worried about using an Australian chip. We have more emissions if nothing else, and 99s are closer to a 5th gen ECU than a 95 ECU.
A 97-99 JWT ECU would be great
-hype
Old Oct 1, 2002 | 09:50 AM
Lime's Avatar
-hype
haha yeah...I'll go show them some leg and see if they come around to our side!
Old Oct 1, 2002 | 10:15 AM
tmkforever's Avatar
Does this powerchip do basically the same thing as a JWT ECU? If not, how are they different?
Old Oct 1, 2002 | 11:11 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
is this the same as the "uniChip" or "The Program" that is located over at Sears Point CA? if it is id stay away from them. THere the ones that blew my friend's motor. Supercharged 10psi and they unplugged the vaccum line to the FMU to get a "base" dyno.
lp's Avatar
lp
As much as I'd like to promote a local company, PC's claims reek of BS. Anyone seriously considering these should search some Australian performance forums before you send your cash.
Old Oct 1, 2002 | 11:28 AM
Nismo87SE's Avatar
That is as easy is repositioning 5 wires and adding 1-2 resistors so one can use a 95-96 ECU.
-hype
Old Oct 1, 2002 | 01:42 PM
xHypex's Avatar
That may be the case for 97-98, but I doubt it applies to the 99s. I know 99s have the NVIS as well as an electrical rather than a mechanical EVAP. Those are the only things I can name off the top of my head, but I doubt swapping a 95/96 ECU would work like it does on a 97.
-hype
Old Oct 1, 2002 | 03:12 PM
CalsonicSE's Avatar
Unichip used to be called the PROgram. I remember someone had it on their SC'ed Maxima a long time ago (I forget who...Steve in Chicago perhaps?).
On a side note, Lyt97SE went to one of their dealers to dyno tune & custom program his ECU & all he ended up with was a blown motor (not from the chip itself; a tech accidentally leaned out his car on the dyno & BOOM!)
edit: oops, I just noticed turbo95max posted the same info earlier in the thread.
Old Oct 1, 2002 | 04:41 PM
Lime's Avatar
I want the right ECU in my car, though.
Old Oct 1, 2002 | 09:04 PM
BEJAY1's Avatar
Conecarver
No product from Powerchip yet
Just got off the phone with Brendt @ Powerchipgroup/EDS. Their marketing group got a little ambitious with that datasheet.
They haven't cracked codes later than Feb 95 ECU's (meaning 3rd gens?) They are workin on the 4th gens and it will be a piggyback unit as mentioned above. He said 1-2 months
Old Oct 2, 2002 | 12:32 AM
lp's Avatar
lp
Re: No product from Powerchip yet
What a load of crap. Don't hold your breath.
So they've admitted to fabricating and distributing a datasheet for an application that doesn't exist? You should ring them back and ask how they came up with the exact 4th Gen power/torque gain figures they advertise.
Blowing an engine while Unichip tuning is nothing more than tuner stupidity, imagine what that idiot would do with a Motec.
Old Oct 2, 2002 | 12:58 AM
Turbo95Max's Avatar
the tech didnt accidently lean it out. It was his own fault due to whatever reason that he disconnected the vaccum line to the FMU. Not sure if the other person was Steve in CHicago but someone with a supercharged Max got it and didnt get much if any gains so he returned it and got his money back. if this is the same thing..i would NOT recommend it.
Old Oct 2, 2002 | 05:32 AM
Lime's Avatar
too bad JWT doesn't have a tech on this site haha.
Old Oct 2, 2002 | 01:36 PM
guido_sst's Avatar
ECUs from before 3/95 are OBD I units, so basically they've done the same thing as everyone else and haven't managed to crack OBD II.
MAXSE5SPD
Sep 17, 2022 04:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
