REQ: FSM scan
Old Oct 1, 2002 | 07:42 PM
jargoone's Avatar
REQ: FSM scan
If someone has a factory service manual and some time, I'd appreciate a favor. I need the instructions for removal of the alternator.
Members have told me in another post that it says to remove portions of the A/C system. My A/C doesn't work after the alternator recall replacement, and the service manager says they didn't touch it. If it does instruct to remove something, I'd like to show them the page and ask why they didn't follow Nissan's instructions.
Anyway, thanks in advance if anyone can scan it and get it to me.
Old Oct 1, 2002 | 08:47 PM
xHypex's Avatar
I don't have a scanner here, but here's the instructions from page El-33
Removal
1 Remove engine undercover RH
2 Remove side inspection cover RH
3 Loosen belt idler pulley
4 Remove drive belt
5 Remove A/C compressor mounting bolts (4)
6 Remove cooling fan and fan shroud
7 Slide A/C compresso forward
8 Disconnect alternator harness connector
9 Remove alternator upper bolt and lower bolt
Installation
To install, reverse the removal procedure.
Hope that helps.
-hype
CorollaULEV
30
Aug 9, 2021 08:11 PM
James92SE
Oct 8, 2015 04:57 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Colossus
Sep 9, 2015 05:46 AM
sdotcarter
Sep 2, 2015 09:53 PM
