front seat problems
Old Oct 2, 2002 | 09:43 PM
redterminator's Avatar
front seat problems
Hi,
I have a 96 Maxima GXE. Ever since I got this car a couple years back, the front passenger seat only moves a little bit but never moves far enought to the front to leave good legroom in the back. I took off the front two bolts and was trying to see what was getting in the way. It sounds like the railing hits something hard on its path and is unable to move beyond that point. Any ideas on what could be causing this?
Old Oct 2, 2002 | 10:59 PM
Nismo's Avatar
I had the same problem but I got it to move back up but it will still jam if I go all the way back. What I did was sat in the seat while racking yourself forward while pulling up on the lever until it finally gets unstuck. I cant really tell what is causing it but it seem that the rails are out of allignment and the seat gets stuck somewhere it shouldnt be.
Old Oct 3, 2002 | 04:58 AM
jargoone's Avatar
Re: front seat problems
Originally posted by redterminator
Hi,
I had this problem on another vehicle of mine. It turned out to be a coin stuck in the rail. After a few times of hitting it really hard, it was really stuck in there. It took me an hour to get it out.
You might have similar, perhaps right under the seat where you can't see it. Try a flashlight and some contortionist tricks, or failing that, remove the whole seat so you can get a good look at it.
Old Oct 8, 2002 | 09:25 PM
thanks for your help
well i took the seat off after a few pushes a nice little bent up penny showed itself in the railing. it took me like 40 minutes to get it out but after almost 3 yrs i can finally move the front passenger seat. thanks for all your help.
Old Oct 9, 2002 | 08:32 AM
burrll_gee's Avatar
Wow another copper catcher!
I had this same problem with my passenger seat, damn loose change. Removing the seat after sliding hard back and forth to find a half cut penny wedged into track. Took me 45 mins to pry out with needlenose pliers!
BG
Old Oct 9, 2002 | 08:38 AM
Vinipux's Avatar
BG
WOW, i thought I was the only one w/ the penny stuck in the railings, weird, how in the world would they even get there???
o well
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
