TSB question
Old Oct 9, 2002 | 05:48 PM
torontoboy's Avatar
TSB question
i saw the below in the FAQ section. what can i do if my 96 has problems listed on this TSB.
torontoboy
http://www.alldata.com/TSB/41/97416257.html
TSB Number Issue Date TSB Title
00-037A NOV 00 Steering/Suspension - Vehicle Pull Diagnosis
00-056A NOV 00 A/T - Oil Cooler Cleaning Procedure
00-085 OCT 00 EVAP Canister - Charcoal Leakage
00-079 SEP 00 Power Antenna - Inoperative
99-053A SEP 00 TPS - Adjustment Procedure Revision
99-048D JUL 00 Battery - OE And Replacement Ratings
00-064 JUL 00 CD Changer - CD Care and Usage Guidelines
00-060 JUL 00 EVAP Vent Control Valve - DTC'S Stored in Memory
00-017A JUL 00 Tools - CONSULT-II Software Update
00-057 JUL 00 Tools - CONSULT-II Repair Procedures
00-054 JUN 00 Engine - Timing Chain Noise
00-044 JUN 00 CONSULT-II - ECM Reprogramming Software
00-033 MAR 00 Brake System - Diagnosis & Repair
00-021A MAR 00 Tools - CONSULT-II NATS Software Update
00-022 MAR 00 Consult-II Software Cards
00-027 MAR 00 Nissan Essential Tool Shipment Summary
00-026 MAR 00 A/C Refrigerant Machine (ACR4) - Maintenance
99-071 FEB 00 99-071 - 02/10/00
99-071A FEB 00 Blower Motor - Noise
00-013 FEB 00 On-Car Brake Lathe Procedure for Steering Vibration
00-015 FEB 00 Trunk Lid - Pops Open By Itself
00-001 DEC 99 Sunroof - Binds/Leaks/Motor Runs But Roof Doesn't Work
99-044B OCT 99 Battery/Starting/Charging System Tester.
99-072 OCT 99 Windshield Washer Spray Pattern Adjustment
99-067 SEP 99 Intergrated Homelink Transmitter
98-008B SEP 99 EGI Harness Wire Breakage Diagnosis and Repair
99-060 SEP 99 Paint Guard Film - Swell, Stains, and Spots
99-022 AUG 99 99-022 - 08/26/99
99-022A AUG 99 Front Seat Belt Latch Plate Stopper Button Missing
92-062A JUN 99 AMMCO On Car Brake Lathe Operating Guidlines
94-012A JUN 99 Brake Judder/Steering Wheel Shimmy
99-005A JUN 99 Brake Pad - Key Value Service Information
99-040 JUN 99 ABS Sensor - Precaution Using On Car Brake Lathe
99-034 JUN 99 99-034 - 06/02/99
99-034A JUN 99 Year 2000 Compliance of Nissan Vehicles
99-011A MAY 99 A/C - R134A Leak Detection (Dye)
99-032 MAY 99 Front Brake - Noise (Groan) When Stopping
99-031A MAY 99 Rear Brake - Noise (Groan/Humming) After Brake Release
99-028 APR 99 Front Seat Belt - Slow Retraction
99-020 APR 99 Towing Guidelines for Nissan Vehicles
99-024 APR 99 Wind Noise Repair
99-017 APR 99 Audio Speaker - Noise (Cellular Phone)
99-010 MAR 99 Odor Coming From Sunroof Sunshade
99-001 FEB 99 Strut - Leak Guideline
98-110 JAN 99 Squeak and Rattle Repair - Supplies
98-106 JAN 99 A/C System Reciever - Drier Replacement Guidlines
98-097 DEC 98 Interior - Squeaks and Rattles
98-101 DEC 98 Spring, Front - Buzzing/Rattle Noise
98-089 NOV 98 O2 Sensor Thread Repair For Exhaust Tube.
98-090 NOV 98 Rear Brake Squeak/Squeal Noise When Cold
98-019A NOV 98 Evap Canister VCV & Evap Canister - Must Match
98-081 OCT 98 Steering - Pull or Drift
98-080 OCT 98 Power Seat - Inoperatrive
98-076 SEP 98 Console Lid - Loose/Disconnected
98-061 JUL 98 Air Bag - Instrument Panel Inspection, After Activation
98-060 JUL 98 Body Repair - Guidlines for Rust & Corrosion
98-063 JUL 98 New A/C Leak Detector
98-011A JUL 98 MIL ON, DTC P0136 Rear Oxygen Sensor
98-029A JUN 98 MIL ON Evaporative System DTC(s)
98-054 JUN 98 Security System - False Alarm
98-050 JUN 98 Spark Knock During Engine Start
98-041 MAY 98 All Hose Lubricant Applications
98-042 MAY 98 Automatic Transmission Fluid.
98-023 APR 98 Dash - Rattle Noise
97-098 FEB 98 A/C System Blowing Warm Air
98-003 FEB 98 MIL ON DTC P1335 - Crank Shaft Position Sensor.
98-005 FEB 98 New A/C Connections O-Rings
97-068 NOV 97 Door Panels - Objectionable Odors
97-046A NOV 97 Power Seat - Lift Adjustment Inoperative
97-057 SEP 97 Intermittent No-Start
97-060 AUG 97 Bumper Refinishing Technique
97-058 AUG 97 Spark Knock - Especially at High Temps
97-053 JUL 97 Park Brake Cable - Hoist Damage
97-024A JUN 97 MIL ON P0300 (Multi-Cylinder Misfire) Due To ECM
97-040 MAY 97 Remote Control System - No Response to Remote
97-028 APR 97 Diag. Prod. For P0731,P0732,P0733 (A/T Signal) With..
97-017 MAR 97 Air Bag Harness Replacement
97-016 FEB 97 Audio Unit - Remanufacturer Matrix
97-013 FEB 97 New O-Ring Connector
97-012 FEB 97 Wheel Balancer Adapter Kit - Use
96-110 DEC 96 A/T Solenoid Valve Replacement Procedures
96-104 NOV 96 Precautions Electronic Control System Testing
96-102 OCT 96 Front License Plate bracket Installation
96-094 OCT 96 MIL Light Icon Change
96-095 OCT 96 Power Antenna Sleeve
96-077A SEP 96 Paint Codes
96-087 SEP 96 Revised Procedure For Detection Refrigerant Leaks
96-084 AUG 96 OBD-II A/T Initial Start Trouble Code
96-050 JUL 96 Consult (Scanner) - Exchange Program
96-032 APR 96 Engine Cranks, But Won't Start Or Is Hard To Start
96-031 APR 96 Service Manual Comment Forms
PI96-002 JAN 96 R134a Charge Amounts/PAG Lubricant Chart
95-114 DEC 95 Clutch Operating Cylinder - Service Information
95-068 JUL 95 Air Conditioning, R134a - Charge Amount/Lubricant Chart
PI95-006 MAR 95 Brake Noises
95-015 MAR 95 Air Conditioning - Installation Procedures
94-100 NOV 94 Recommended Fluids, Lubricants & Chemicals
94051 SEP 94 Bumper Refinishing Techniques
94-077 AUG 94 Enhanced Emission Inspection/Maintenance Program
94-009 MAR 94 Battery Charging/Replacement Procedure
94-015 FEB 94 Paint - Contamination Identification and Repair
94-011 FEB 94 Starting & Charging System General Diagnosis
94-004 JAN 94 Differentials - Recommended Lubricants
93-109 JUL 93 Paint Finish - Maintanance/Storage Recommendations.
93-112 JUL 93 Seat Belt Extenders
93-017 JAN 93 Cassette Tape Player - Maintenance
92-001 JAN 92 Changes to A/C Systems as Result of R-134A Refrigerant
91-096 DEC 91 ABS, Self Check - Noise
91-046 MAY 91 Consult Lithium Battery Replacement
90-090 OCT 90 Angular Tightening
90-044 MAY 90 Cassette Tape Player Maintenance
89-131 AUG 89 Silicone And PBC Greases
88-015 FEB 88 Cautions for Aftermarket Rust Proofing
87-172 NOV 87 Automatic Transmission - Cleaning Components.
TS87-150 OCT 87 Nissan Genuine Buckle Assembly For Use With Child Res..
87-103 JUN 87 Disc Brake Noise Information.
87-064 APR 87 Plastic Lens - Isopropyl Alcohol Caution [/B][/QUOTE]
Old Oct 9, 2002 | 05:56 PM
Bags's Avatar
VG Ridah's Biatch Hoe
take it to the dealer and have them check the VIN to see if any of the TSB were done to your car.. if not try and get them done
Old Oct 9, 2002 | 06:21 PM
torontoboy's Avatar
Re: TSB question
what are the chances of getting the stuff done for free or cheap?
torontoboy
[/B][/QUOTE]
Old Nov 15, 2002 | 06:46 PM
ThurzNite's Avatar
Re: Re: TSB question
[/B][/QUOTE]that's the same question I have. I get brake noise when releasing brake and moving slowly.
Jae
Old Nov 15, 2002 | 07:23 PM
Jamsan's Avatar
if they are recalls, im assumin they have to fix it for free
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
