auto dimming rear view mirror??
Old Oct 9, 2002 | 07:39 PM
ny96max's Avatar
Does anyone know of an auto dimming rear view that can be used on the 4th gen?? I thought the Inifinty I30 had these stock, or am i wrong
or if no dimming mirror exists for us, maybe one with a built in compass or outside temp?
Im sure someone here has this in their car!
thanks,
Ant
Old Oct 9, 2002 | 07:42 PM
maximised's Avatar
Re: auto dimming rear view mirror??
thanks,
Ant
I am 98.9253% sure the infiniti's had them.
Old Oct 9, 2002 | 08:47 PM
HTownMaxSE's Avatar
The auto dimming for the I30's were a feature that you could add on. I think the mirror is around 200. Because my AcuraTL auto dim mirror broke and i had to get a new one.
Old Oct 9, 2002 | 09:35 PM
DaddyMac's Avatar
I know they have aftermarket ones, don't remember the site. they cost about $150-$200 each with compass and temp.
Old Oct 9, 2002 | 10:35 PM
co_maxima98's Avatar
But do the aftermarket ones work with our cars? Ours are attached to the headliner and most of the aftermarket ones I keep finding just attach to the windshield. How would that work out?
Old Oct 9, 2002 | 10:42 PM
Kevin's Avatar
I have one in my car from a 97 I30. Unfortunately I don't know how to wire it up there are four leads comeing out of it but oonly one is black ( ground) don't know what the rest are.
Kevin
Old Oct 10, 2002 | 06:24 AM
karguy's Avatar
97 Infinti I30 comes with it, very nice feature. Called electro chromic mirror. I would check junk yard!
Old Oct 10, 2002 | 07:00 AM
I30tMikeD's Avatar
Re: Re: auto dimming rear view mirror??
you can make that 100%
Old Oct 10, 2002 | 07:16 AM
Kevin's Avatar
anyone with an i30 want to help me out by checking the polarity of th wires?
Old Oct 10, 2002 | 07:21 AM
maxperformance's Avatar
Lexus Has Then. .But There A bit Different
My dad has a '95 Lexus SC300, and that has some sort of a liquid crystal mirror. So at night when all the headlights are in your face from behind, you just push a buttom and the rear view mirror dims. Its pretty sweet, i have no idea how it works or if thats what your looking for. Just trying to help, peace
Old Oct 10, 2002 | 03:13 PM
ny96max's Avatar
thats great you guys know of these. But where can i buy one??
Ant
Old Oct 10, 2002 | 05:13 PM
genepool's Avatar
I can only tell you what it says in my FSM....I should have a scanner in a couple of days and I can post the wiring diagram.
(1)Black gets splice with (3)Black of the illumination control switch
(2)Red w/ yellow stripe connects to (2) Red w/ yellow stripe of the illumination control switch
(3)Red w/ Blue stripe gets spliced with (1) Blue w/ Yellow stripe of the illumination control switch
(4)Green w/ Blue stripe goes to a Green w/Blue wire(might not be in your car) to 10A fuse #13 (in car fuse block under the instrument panel)
Hope this helps. If you want a scan, I can try and get you one over the weekend.
Old Oct 10, 2002 | 05:23 PM
Kevin's Avatar
A scan would be great man! Thanks, is there anyway your FSM would say what the polarites of those wires are? if so I could probably just wire it up to the sunroof map light. is the illum control switch the dimmer switch??
Old Oct 10, 2002 | 06:14 PM
genepool's Avatar
I don't think the book has polarity but then again, i could be wrong (I wasn't an EE major). The illum control is the dimmer switch.
Also, if it was hooked up to the map light, wouldn't your dimmer be on at all times? I think that's why it gets hooked up to the dimmer switch, it only has power when the car is on or key turned (i could be wrong again).
Old Oct 10, 2002 | 06:50 PM
SuperFishstick's Avatar
I've seen on in one of those order catalogs, i believe it went for like 250 or something. It fits most cars, except imports. You would also have to buy a seperate mounting bracket that went for $70 or something close to it. I bet you can find one online (ebay ) for a lot cheaper. Good Luck
Old Oct 10, 2002 | 08:04 PM
Kevin's Avatar
thanks, The problem have now is how to I get those wires routed over to the dimmer
Good point about the map light. it may even be that it will only turn on when the map light is one. that woudl suck! Thanks for your help it's a great starting point to figure out how to wire this thing.
Old Oct 14, 2002 | 08:34 PM
genepool's Avatar
Here is a link to the wiring diagram. The picture is 325K.
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
