pix of my gauge rings...
Old Oct 11, 2002 | 02:14 PM
J Steed's Avatar
40 bux off ebay, such a deal!
Old Oct 11, 2002 | 02:30 PM
redmaxpa007's Avatar
i SeE what you did therE
i like mine better...
Old Oct 11, 2002 | 02:32 PM
J Steed's Avatar
lol, they look the same to me minus i dont have the aluminum bezel
Old Oct 11, 2002 | 02:35 PM
it is chrome not aluminum..(Cefireo bezel)
and do not for get eh www.eatricezone.com sticer..
Old Oct 11, 2002 | 02:38 PM
Jepht20's Avatar
Custom User Title...
j steed, looks good. are those the chrome ones or gunmetal? hard to tell from the pic...i'm thinking about getting these.
redmax, howcome your gas guage is set up different? it's flipped around and doesn't have a half way mark(not that it's really half anywa).
J Steed's Avatar
ok ya got me on those 2 points...
and i just noticed yers is the 007 max, my 2nd fav gen4 behind mine lol
Old Oct 11, 2002 | 02:40 PM
J Steed's Avatar
they are the chrome ones & thanks
Old Oct 11, 2002 | 02:41 PM
Tifosi's Avatar
Re: pix of my gauge rings...
Looks good, but they almost look like they aren't thick enough.
Tifosi
Old Oct 11, 2002 | 02:43 PM
i have a 99.. they fuel gauge is proper.. not like yours..
and i never had a half way mark on my SE-L gauges.. hmm.. i have indiglos..
Old Oct 11, 2002 | 02:45 PM
Gotrice4's Avatar
I believe redmax007 has a 99 SE-L, which has an electronic odometer and a slightly different gauge cluster, i believe this is correct...
Old Oct 11, 2002 | 02:46 PM
.. wait till spring.. you will like mine better than yours..
Old Oct 11, 2002 | 02:48 PM
J Steed's Avatar
hmm, probably, most days i hate this darn car
Old Oct 11, 2002 | 02:49 PM
bbwhahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahaha.... breath...hahahahahahahahahaahahahahahahahahahahaha hahahahahahahaha
Old Oct 11, 2002 | 02:52 PM
J Steed's Avatar
damn thing, if i had the maxima since it was new, id like it better
but i was spoiled from my last car *sigh*
Old Oct 11, 2002 | 05:23 PM
ny96max's Avatar
I never liked the look of both an aluminum gauge bezel and rings looked together, especially over white faced gauges. Makes things look way to cluttered in there.
I just have the chrome rings over my white faced gauges and i get nothing but compliments all the time
Ant
Old Oct 11, 2002 | 07:48 PM
Requin6's Avatar
i like them...i think i might just want to get the rings...how hard are they to put in?
Old Oct 11, 2002 | 08:03 PM
95emeraldgxe's Avatar
Ant
i think it looks awesome! the only thing i dont like is the sticker ..............btw - your 40 dollar chrome rings look pretty good - for some reason they do look thinner than other ones though.
Old Oct 11, 2002 | 08:18 PM
WizzaMax's Avatar
The rings are VERY easy to put in...
Remove bottom plastic piece under steering wheel(2 screws and 2 pressure clips)
Remove metal bracket under that...(2 small bolts)
Remove nuts from two bolts holding steering column up in place and lower onto floorboard(use extension and look at side of bolt in between SW and dash edge)
Remove plastic gaige surround(2 screws at top and pressure clips on the bottom) [You may want to disconnect electrical connectors to prevent stretching connector for security light,cruise and dimmer]
Use flathead screwdriver of finger to loosen clear plastic tabs all around front of gauge pod (It is easy to remove gauge assembly by 3 screws and just pull forward slightly to reach all tabs)
Remove clear lense and set aside
Insert rings appropriate to corresponding bezel and press flush
Reassemble in reverse and tigheeten everything up and enjoy the newly found perspective...like me
Old Oct 11, 2002 | 09:39 PM
Requin6's Avatar
wow..thanks wizza...excellent info...
are these normally $40? or is that an ebay ******? i have seen these before but not really payed much attention to the details. j steeds pic caught my eye
Old Oct 12, 2002 | 12:03 AM
J Steed's Avatar
yea, i noticed theyre a tad smaller, i think its cuz you can use the carbon and aluminum bezel with them, but with the other you can only use the cefiro one...dont quote me
i got mine on ebay, theres some for sale there all the time, and syferio has/can get the real ones...
Miket2006
Mar 1, 2021 03:55 AM
AcuraLegend
Oct 17, 2016 08:47 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
