A new one for SC people ->
Old Dec 22, 2000 | 09:11 PM
Loren00Miata's Avatar
I found a new item that needs to have routine maintenance done with a supercharger: the Blow-off Valve. I noticed at the meet that my Blitz BOV was not staying open at idle. I checked it out. I found out the BOV was only opening when I let off under high boost. At vacuum or low boost conditions, it was closed. I removed my Blitz and disassembled it. The problem was that there was debris built up in it. I had to clean the piston and chamber with carburator cleaner. This was similar to the buildup seem over time in a throttle body or carburator. After cleaning and reassembling the Blitz, it was back to normal operation. Best guess is that the BOV needs to be cleaned every 10-15,000 miles.
Old Dec 23, 2000 | 12:29 AM
Chunger's Avatar
My other car is a Hybrid
You shouldn't be getting any carbon build
up that far up the intake...
IIRC, the BOV isn't supposed to be open except when you let off on the gas when you shift... otherwise on some cars (although not the case in the SC Maxima) the ECM wouldn't be reading the right amount of air if the AFM was ahead of it during idle.
litch
123
Jan 4, 2024 07:01 PM
gavin68
Sep 18, 2021 12:36 PM
mkaresh
Mar 12, 2018 06:48 PM
REDinLV
Sep 28, 2015 12:31 AM
