95Maxima Se cylinder 3 misfire please help!!
Old Oct 14, 2002 | 09:55 AM
95CustomMaxima's Avatar
I was driving my maxima and all of a sudden my engine light popped up, so I drove my max home and checked the codes on the ECU and it brought up a 0606 code (cylinder 3 misfire). I have been having some horrible luck with fuel injectors, which i think is the problem..The exhaust is puttering when at idle. I need some help real quick please
Also after I reset the ECU and went out driving again the check engine light popped back up and was blinking this time. What does that mean if its blinking.. I need some help real bad, I can tell a loss in acceleration also..PLease Help me
Thanks in advace,
Nick
Old Oct 14, 2002 | 09:58 AM
Sprint's Avatar
read my responses in this thread.. its the same concept
http://forums.maxima.org/showthread.php?threadid=158730
Old Oct 14, 2002 | 10:36 AM
Those links you had in that thread were invalid..The last one worked...Please help me out guys
Nick
Old Oct 14, 2002 | 11:31 AM
Sprint's Avatar
Nick
server change fcked up cookies
DTC 0201
http://forums.maxima.org/showthread....t=DTC+and+0201
Check Bad Coil Pack
http://forums.maxima.org/showthread....pack+and+check
Old Oct 14, 2002 | 12:42 PM
JAIMECBR900's Avatar
According to the Haynes manual, 0606 also indicates a rich/lean bank of cylinders (can't remember if front or back).
Have you taken your plugs out and checked those? I had a similar problem on the dyno the other day, same code. Looking at the condition of ALL the plugs, remember which you pulled from where, is a good indicator of what ignition problem you have.
BTW, cylinder #3 is in the rear bank, but check all the plugs so you can compare them to each other and also see if there are additional cylinders acting up.
Old Oct 14, 2002 | 05:47 PM
Thanks for the help guys..im gonna try that later..anybody else have anthing else i can try in case it is something different.
Thanks again,
Nick
Old Oct 15, 2002 | 04:56 PM
anything else before I try this weekend
Old Oct 15, 2002 | 04:57 PM
Jamsan's Avatar
i got a cylinder misfire 1 code just yesterday as well...my friend came over, (he had a bunch of extra coil packs), so we swapped it out, and that fixed it right up....try this....start your car, and unplug the connector that goes to coil pack for cylinder 3 (rear right)...if the car is still the same, then you know theres something wrong with that pack....also do the same for the next one over, and notice the change in idle..
Old Oct 16, 2002 | 10:01 AM
What was your car running like prior to the coil exchange?? Did your exhaust putter..like if you went to listen to the muffler you could tell it was misfiring by the puttering? Also what symptons/problems was your maxima having with a cylinder 1 misfire..
Thanks,
Nick
Old Oct 16, 2002 | 04:21 PM
Jamsan's Avatar
well ill tell you exactly how it happened, and how it felt afterwards...i was pulling up to a light, and my car just made a really loud clunk, and then my check engine light came on, and the car just starting idling like ****....if my foot was on the brake, it wasnt half bad, but when i eased off the brake, and then fully let go of it, it was rolling like it was a jumping monkey on crack....it was bad....then i would try to accelerate, it would bog like no tomorrow, and then when it would switch over to the other cylinders, it would be fine...i really didnt hear the exhaust much, so i couldnt tell you what it sounded like....but the power sucked, it would buck around town and on the highway, and its really bad....try disconnecting the connector to the cylinder 3 coil pack (the rear right one), and see if the car remains the same...if it does, unplug the one next to it (the left side), and if the idle gets worse, or you can notice a change in sound, most likely the coil pack you previosuly tested is ****ed....well gl
Old Oct 16, 2002 | 08:56 PM
Thanks For the help all...the weekend is coming up soon..so I'm gonna see what happens and ill post back with the results
Thanks Again
Nick
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
