Mevi
Old Oct 20, 2002 | 11:41 AM
ross's Avatar
Mevi
I tried searching but can someone tell me exactly what this is?? I know it has something to do with the intake but I just cant figure it out.. lol. THanks
Old Oct 20, 2002 | 12:07 PM
96BLUMAX's Avatar
Middle East Variable Intake.
Basically 4th gens don't have it.
The 2k2 has it.
It allows power up to redline.
Old Oct 20, 2002 | 01:17 PM
Scruit's Avatar
U wanna try me young boy?
The MEVI, Middle East Variable Intake (Don't know the official name) is a 4th Gen thing...
The Infiniti I30 is sold in the Middle East (Bahrian, Saudi etc) under the name Maxima, and it has a specially-designed intake.
It's not a true Dual-Plane intake (like the Taurus SHO, or the 3.8 SPI from the later model Windstar/Mustang) which has two distinct air paths from the air filter to each cylinder (one long, for low revs - one short for high revs). Instead, it's a Dual-Plenum design that has a second plenum directly above the lower intake, providing a shorter path for the Dynamic Supercharging effect (described below). The second plenum is 'activated' by opening a set of butterfly valves. These valves are opened by a vacuum actuator at the appropriate engine speed.
Dynamic Supercharging is the concept that when the intake valve closes it causes a pressure wave to travel from the outside of the intake valve back towards the air filter. When the pressure wave reaches the plenum (the common part of the intake track between the throttle body and the individual runners) it bounces back towards the intake valve. If the intake valve opens just as the pressure waves gets back, then more air is forced into the cylinders and it increases the volumetric efficiency. There is a specific engine speed at which this Dynamic Supercharging effect happens, and the length of the runners changes this engine speed, because of the time it takes the wave to travel.
Intake spacers change this effect to a lower engine speed (because the wave takes longer) giving the engine more bottom-end grunt (marginally, and at the cost of mid-range grunt)
The dual-plenum design gives the engine TWO speeds at which dynamic supercharging happens - at high speed the upper plenum valves open and the shorter path to the upper plenum gives the dynamic superchargin effect at higher engine speeds, increasing breathing and prolonging the powerband.
That's it, in a nutshell.
Old Oct 20, 2002 | 01:24 PM
ross's Avatar
so when ppl say that they have sent off to get their MEVI, what exactly does that mean. In other words, what do you send off and what do you get back. Do the people who do this do something to your car or do they send you something brand new. Any pictures??
Old Oct 20, 2002 | 01:28 PM
mzmtg's Avatar
Minister of Silly Walks
Perfect answer!
...added to the FAQ...
Old Oct 20, 2002 | 08:55 PM
multiplexor's Avatar
sent off money
they get the mevi shipped back to them just like ordering something online... which is.. err... basically what your doing
Old Oct 21, 2002 | 08:40 AM
JeffesonM's Avatar
living out of a maxima...
check out Group Deals forum for dynos, pictures and info on where to buy
Old Oct 21, 2002 | 09:32 AM
iansw's Avatar
www.cyberhub.net/intake
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
