ECU popping out all different codes- What should I change? please give your opinion
Subscribewhen my cel first came on I checked the codes and the KNOCK SENSOR and ENGINE COOLANT TEMPERATURE SENSOR(ECTS) came on ,
so i reset it , then the KS code came on with the rear O2 sensor and the ECTS code disapperered, so I rest it again
Then the KS code came on with the front right O2 sensor code ,
so I reset it again and the KS and the rear O2 sensor came on
SO finally I changed the KS and rest the ecu
Now after I changed My KS, the KS code came back on with the ECTS code
Now my question is which one should I change
Front O2 sensor?
rear O2 sensor?
ECTS?
Also is there any reason why my KS code came back, I changed it a week ago(BTW even though i changed the KS i still dont feel any differnce in power or gas milege)
I know reading this thread is more confusing than I am on what to do
but i greatly appreciate any advice
thanks for any info
Front O2 sensor?
rear O2 sensor?
ECTS?
thanks for any info
We told you a few days back to change the Engine Coolant Temp Sensor and reset the ECU first and not to change the KS or the O2's didn't we??
Forgive me if your not the same member.
So you went and changed the KS anyhow and now your back where you started from. NICE!
1) CHANGE THE ENGINE COOLANT TEMP SENSOR!
2) RESET THE ECU
3) IF THE O2 COMES BACK, CHANGE IT.
4) NEXT TIME LISTEN TO US THE FIRST TIME.
2) RESET THE ECU
Yeah thats the order i would do it too. The o2 sensors are most likely tripped from the coolant problem. That actually happened on my old engine.
Out of curiosity, the ECTS has been sited as causing hard starts when bad. DO you have this problem?
sorry i didnt relize anyone responded to my last thread so i put this up , I'm not getting any email notifications, anyway so I changed my KS for nothing
, I am gonna change the ECTS now, thanks for the info guys, and no Mishmosh my car hasnt had a problem starting , it did when i first had it and before i did a tune up in january, but now it starts up with no problem , but i still am gonna change the ECTS , thanks for all your help fellasHey I wouldn't sweat replacing the KS. So many of us with 95/96's have done so. I think it's just a forgone conclusion that that these things will go bad...
