Slip and TCS off Light
Old Oct 24, 2002 | 12:27 PM
dopeymax's Avatar
Hey guys i seem to be having a problem with my Slip and TCS off light coming on every once in awhile. When they do come on i feel strong vibrations throughout the car and then the lights come on. Any advice on what i should do? Thanks guys
Old Oct 24, 2002 | 07:59 PM
dopeymax's Avatar
bump
Old Oct 25, 2002 | 08:23 AM
dopeymax's Avatar
Originally posted by dopeymax
bump
Anybody know whats goin on ?
Old Oct 25, 2002 | 10:45 AM
njmaxseltd's Avatar
Are your tires spinning upon take off? Or are you just driving along, coasting and this happens.
Old Oct 25, 2002 | 02:51 PM
fatcatpat's Avatar
Re: Slip and TCS off Light
what size are your rims?
Old Oct 25, 2002 | 08:54 PM
dopeymax's Avatar
im just driving along and this happens i do need to replace my knock sensor but i dont see how that would have anything to do with it and its about time to change my transmission fluid. My rims are 16".
Old Oct 25, 2002 | 10:05 PM
iansw's Avatar
I wasn't aware that the 4th Gen Maxima HAD TCS!?!?
Must be a GLE option?
IanS
Old Oct 25, 2002 | 11:26 PM
mAdD MAX's Avatar
IanS
I believe only the 99 Maxima GLE had TCS. I know mine does.
If you get vibrations, it could be your engine mounts? If your TCS and SLIP light are constantly on that means something must be wrong with the TCS system.
Old Oct 26, 2002 | 07:29 AM
njmaxseltd's Avatar
My 99 SE-Limited has TCS.
I think dopey max may have a sensor failing in his ABS system. The ABS and TCS work together. The traction control system uses the signals from the ABS sensors to detect wheel spin.
Might want to have the dealer take a look at your car. What puzzles me is you feel vibrations in the car. The only thing I can think of which would cause your vibrations would be the ABS system itself. It may be getting flase signals from a sensor and think you have a lock up condition and activation the ABS system. Of course your not on the brakes so nothing really happens but you may be feeling the vibrations of the stepper motor trying to pulsate your brake system.
Old Feb 19, 2003 | 09:42 AM
cgardine's Avatar
I just had the same problem happen on my '02 SE today. It seems to me that the problem had something to do with snow/ice buildup in the wheel wells. Does your problem occur during/after snow?
Old Feb 19, 2003 | 10:10 AM
njmaxseltd's Avatar
Re: Re: Slip and TCS off Light
Absolutely! If you get snow packed into the wheel and it manages to get behind the rotor where the pickup sits it could interfear with the sensor and cause the system to detect a failure.
We have a Passat here at work that trips the ABS system every time we bring the car through the car wash. Dealer told us it's common with that paticular year.
Old May 4, 2003 | 03:02 PM
My4DSC's Avatar
My 99 SE-L has TCS also...SE-L's ROCK!
Old May 4, 2003 | 07:29 PM
d_hammmer's Avatar
Does your "service engine soon" light come on at the same time? On my 99 Max SE, all three lights came on and the car started to stumble. When I check the ecu, it gave me a 02 01 and 06 07 (misfire cyl 2)and the standard 03 04 (knock sensor).
I replaced the ignition coil on Cyl #2, and reset the ecu and all was well.
I believe that the Slip and TCU comes on for some reason at the same time as the SES ( Must be sympathy )
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxie40
Sep 14, 2015 11:28 AM
