where can i get 2 rear replacement struts cheapest?
Old Oct 24, 2002 | 03:55 PM
Jepht20's Avatar
Custom User Title...
i was gonna just use someones stock struts as replacement for my blown rear ones, but the ones i got from someone were no good, so i figure i'll just get new ones. does anyone know what are the cheapest ones and where i can get them? i know tokico blues and KYB GR-2's are usually what people get(i don't have the $$ to get kyb agx and don't feel the need for sporty ones)...so, anyone have any ideas where i can just rear two really cheap? all i want is ones that will last and aren't crappy, i'm not looking for anything fancy or sporty. thanx
Old Oct 24, 2002 | 03:57 PM
SuDZ's Avatar
Get the GR-2's then. Not too much and are basicly just all you need.
SuDZ
Old Oct 24, 2002 | 05:20 PM
JPMax's Avatar
What's next!?..
I think at tirerack.com the rear gr-2's are like $50 each.
Old Oct 24, 2002 | 09:35 PM
Jepht20's Avatar
thanx guys,
at tirerack they were 58 each...sorry to ask same old questions but do i need the mounts too? is that something i would have to check on my car to determine if i need them, or??
Old Oct 24, 2002 | 10:14 PM
ny96max's Avatar
if you really wanna stoop realy low, buy a set of Monroe Sensitracs, they will run ya like $40-50 a pair from Autobarn, lol
Ant
Old Oct 24, 2002 | 10:43 PM
JPMax's Avatar
What's next!?..
Originally posted by Jepht20
thanx guys,
How many miles do you have on the car? You will most likely need new dust boots if you have over 80k.
Boot choices are pretty limited. OEM Nissan or KYB (from Cattman.com)
Mounts are probably ok unless you live up in the frozen north somewhere (Canada)
Old Oct 24, 2002 | 11:58 PM
Jepht20's Avatar
are those monroe really bad or worth laughing at? i know they're not for performance but as a strut/shock, are they that bad?
i have just under 90k and live 30 minutes south of boston.
i don't mean to seem like the biggest cheap skate...i am just in college and have no money really and want to just replace them so that damn noise goes away...performance shmormance....just need cheapest solution that won't crap out.
one other small question, since stock ones are struts and it seems all aftermarket ones are shocks(?)...do they just directly fit in there or does other stuff need to be changed. i'm almost sure they work the same, just want to make sure.
Old Oct 25, 2002 | 04:58 AM
95Max's Avatar
For a little extra $$ go for the GR-2. They are much better quality. In ride and construction.
Old Oct 25, 2002 | 07:54 AM
JPMax's Avatar
What's next!?..
Here's basically what you're looking at..
(2) KYB GR-2 rear struts $60 each = $120 Direct replacement
(2) OEM Nissan rear boots $25 each = $50
Installation through a mechanic $50-100
all rates are approximate. So plan for about a $250 job altogether.
If you drive around with bad struts for too long, your tires will go bad too and then you have to spend even more money to replace the tires.
Old Oct 25, 2002 | 09:23 AM
SuDZ's Avatar
Dont bother getting a mechanic to do it. It is an easy job. It wont take you more than two hours or so.
SuDZ
Old Dec 2, 2002 | 09:34 AM
sharkyjay's Avatar
I just had the monroe sensatracs installed and it's worst than I could have ever imagine. It's a lot more bumpier than the worn old struts. It's a smoother ride in my old 92 corolla.
-JT
Huttig2009
Sep 25, 2015 03:31 PM
MaxStock
Aug 14, 2015 09:59 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
MaxStock
Aug 8, 2015 01:18 AM
laparka66
Aug 6, 2015 09:36 AM
