how to flush power steering system
Old Oct 25, 2002 | 08:52 AM
s2cmpugh's Avatar
sup peeps, i was curious if anyone here had any good writeups or instructions on how to flush out the power steering system. nissan wanted 90 bucks and i told them hell no.
also i want to use some amsoil synthetic fluid in there, does anyone know if they sell it???
thanks
Cris
Old Oct 25, 2002 | 09:58 AM
karguy's Avatar
Re: how to flush power steering system
thanks
Cris
AMSOIL ATF meets Nissan Spec for Power Steering Units. Bought a new battery water syringe from Advance Auto. Used it to suck fluid out of Power Steering Resevoir then refilled with AMSOIL ATF. Over a period of a month I did this 6 times. That was 4 months ago. I am now running AMSOIL Synthetic oils in my engine (0W-30), Automatic Transmission and Power Steering Unit. At idle in drive the car is super quiet!
Old Oct 25, 2002 | 11:01 AM
s2cmpugh's Avatar
well i cant afford amsoil yet, but i did get some valvoline supersyn power steering fluid, like 4 bucks a quart so i think its good.
is this stuff ok to use????
thanks
mayhem_J30's Avatar
Re: Re: how to flush power steering system
what you did is pretty much what i did on both my infiniti's. just used a pump to get out what i could from the resivoir then refilled. did multiple times and refilled with Valvoline ATF Synpower.
I always do the color test.
Put a drop of new ATF fluid on paper towel, then put a drop of old fluid on towel. I keep draining and refilling until they match. Should be a bright blood red.
Old Oct 25, 2002 | 11:50 AM
karguy's Avatar
Re: Re: Re: how to flush power steering system
Actually I did it on 97 SE and 97 I30. I've been very impressed with Infiniti Service, free loaner and car washes, I'll probably get another Infiniti later on. Great car great service!
Old Oct 25, 2002 | 12:34 PM
funnylittlman's Avatar
what about sucking out the resevoir, and then turning the car on briefly to get the rest out?
Or will that burn out the P.S. ... just me thinknig
I bet it would though.....
Also, what color should the fluid be? Bright red?
Old Oct 25, 2002 | 01:43 PM
mayhem_J30's Avatar
read my post a couple up for color.
you do NOT want to empty the resevoir them run the car. just like brakes you can get air in the system and that's not good. it's easy to do by just emptying and refilling and trained monkey could do it. and there's no risk.
Old Oct 25, 2002 | 03:09 PM
karguy's Avatar
Color is bright red, same as ATF. I wouldn't try to pump the rest out. When I try things like that I do more damage than good!
Old Oct 25, 2002 | 10:13 PM
talisman311's Avatar
How do the free carwashers work?
I'm curious how the car washers work, since i drive a '99 myself. I didn't buy it from my local infiniti does that matter? I heard it was a saturday morning only thing.
lowpost99
Oct 26, 2025 06:53 PM
sctludwig
Sep 1, 2022 01:32 PM
BkGreen97
Apr 2, 2016 05:47 AM
trungg86
Sep 4, 2015 04:58 AM
coasterswim
Sep 2, 2015 07:43 AM
