Brake Light.
Old Dec 24, 2000 | 10:26 PM
MaxDawg
Have any of you had this happen? When I go to my car, 1996 Se 5-spd, in the morning turn it on and take off the parking brake, the red "brake" light stays on. The wierd thing is that it turns off after the car is driven for a while. the only thing I can think of is that the brake fluid is a tad too low and when the warm engine expands it, it untrips the sensor. Does the light even have anything to do with that sensor? Or what else could it be?
thanks in advance.
Old Dec 25, 2000 | 08:20 AM
MacGyver's Avatar
The connection on the break could ber loose. When the brake is released it makes a connection and turns off the light, when it is pulled up, the connection is broken and the light comes on....it could be loose or dirty....it happened in my old mustang....when i shook the brake when it was down and the light was on the light would go off after i shook it a little....i don't know if there is anything more to it, like a sensor or anything. I'd make sure everything is tight first. Hope this helps.
Old Dec 25, 2000 | 08:37 AM
Daniel B. Martin's Avatar
Originally posted by MaxDawg
... ...the only thing I can think of is that the brake fluid is a tad too low ...
The brake warning light serves two purposes.
1) Handbrake is applied.
2) Brake fluid reservoir is low.
Make sure the handbrake has been fully released.
Check you brake fluid reservoir and replenish as necessary.
Read your Owner's Manual for further information.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
