ecu code question
Old Oct 25, 2002 | 09:24 PM
brodaiga's Avatar
ecu code question
hey, i'm selling my other max and the check engine light came on after taking apart the filter and changing the cv joint the two codes are:
0807: EVAP Canister purge control valve/soenoid valve circuit
0102: MAF sensor
Now, I don't really mind the 0807, but if I fix the 0102 by restting the ECU or fiddling with the MAF, will the 0807 code trip the check engine light or is it a ghost code???? Thanks.
Old Oct 26, 2002 | 07:03 AM
iwannabmw's Avatar
Re: ecu code question
0102: MAF sensor
What filter did you take apart? The MAF code is probably a loose connection. 0807 will trip the light by itself.
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
Johnny9595
Sep 3, 2015 05:18 AM
