Speed limiter
Old Oct 27, 2002 | 12:49 PM
2maximas's Avatar
Speed limiter
Read the FAQ and discovered which wire feeds the ECU the speed info, putting a switch in is a good idea for those limited times you want to go fast, however, what feeds the ECU? I realize the speedo output is where it comes from but does it go thru the gauge cluster first (to feed speedo) or is it a direct wire from the speed sensor to the ECU. The reason I ask is could it be possible to replace a GXE gauge package with an SE package and therefore eliminate the problem? I do not have a good wiring diagram.
Old Oct 27, 2002 | 08:24 PM
dudevolley's Avatar
You got a good question. I would get a Haynes Manual..their wiring diagrams are good if you know what your doing. I think someone has put in a switch on the board. Try to search for that, and get info from them.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
