Need help with my Hanabi HID KIT
Old Oct 30, 2002 | 09:19 PM
HTownMaxSE's Avatar
I just got my HID kit. Got evertyhing to work, but I don't know what to do with the fuses and all the mouting stuff. Where did ya mount the started and ballast, and how did ya do it. Cause freddie said keep away from heat and water. And where do i put the fuses, i have 2 20's and a 40 fuse. Please help. I think its going to rain tomorrow. I just have my ballast and starter piled up in each corner.
Old Oct 30, 2002 | 11:29 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I mounted mine by the metal bracket. It's the upper radiator support. You can use the 2 sided tape to attach the starter to the ballast. Then I mounted the ballast with the attached starter to the holes present in that upper radiator support using zip ties. I did this to both sides.
Iilac
Old Oct 31, 2002 | 06:35 AM
Lime's Avatar
Iilac
I actually made custom brackets from metal for mine...attached to the same place though.
Old Oct 31, 2002 | 07:49 AM
HTownMaxSE's Avatar
Where do i put the fuses?
Old Oct 31, 2002 | 08:13 AM
ny96max's Avatar
i pulled my headlight and corner housings off and mounted the ballests under them on a support beam. And the starters are mounted right next to the readiator on the back of the headlight assemblies. Both the ballest and starters are screwed in and not taped! And all harness's and wiring is black wire loomed too. As far as wiring i made my own quick connectort to make the entire system a real "plug n' play".
Ant
Old Oct 31, 2002 | 09:37 PM
HTownMaxSE's Avatar
I got that point now. But i still have 3 fuses that came in the box that are just sitting in there. What do I do with them
Old Nov 1, 2002 | 04:26 AM
97GLES's Avatar
your car uses 2 fuses for your headlights. they are in the fuse box next to your battery. you should have a 15 fuse, try to up-grade it with a 25 fuse.
Old Nov 1, 2002 | 04:58 AM
Lime's Avatar
The fuse boxes (which are handily labeled) in the maxima are easy to get at. The one you want is right near the battery, on the side. My Hanabi kit came with the wrong size fuses, so I went to Pep Boys and got 25w fuses of the correct size, and replaced the 15w ones that were in there.
Old Nov 1, 2002 | 06:29 AM
Mishmosh's Avatar
Hmm. I didn't swap any fuses. No problems. Although the startup current surge is higher, these HIDs use less power than halogens.
Old Nov 1, 2002 | 10:14 PM
HTownMaxSE's Avatar
What do i do with the 40 one.
Old Nov 1, 2002 | 11:57 PM
ny96max's Avatar
i didnt even touch the fuses and mine are still fine almost a month lata!
Ant
Old Nov 2, 2002 | 02:05 AM
Iilac's Avatar
I haven't touch my fuse yet and I have had them for about 4 months now.
Old Nov 2, 2002 | 07:03 AM
97GLES's Avatar
all hanabi hid owners should up-grade the headlight fuse.
this is to help the stater do it's job.
Old Nov 2, 2002 | 09:47 AM
PCGuRu2K's Avatar
Even for us 5thgens... I had my kid running on the stcok fuse for almost a yr now and no probs..
Old Nov 2, 2002 | 01:28 PM
HTownMaxSE's Avatar
AHHHHHHHHHHHHHHH...... No one is answering my ????? What do I do with the 40w fuse.
Old Nov 2, 2002 | 03:10 PM
Mishmosh's Avatar
Store it. You don't need it. Like 97GLES says, replace the stock 15A fuses for the headlights in the engine bay fuse box to 25A. If you don't want to change the fuses, then don't as many of us haven't had any problems with doing so.
The Hanabi Kit has many misc. parts you don't need. Don't feel like you need to use them all. BTW, the fuses in the engine bay are of the "mini" variety so more than likely, you'll have to get them from your auto parts shop.
Old Nov 2, 2002 | 09:46 PM
97GLES's Avatar
thank you Mishmosh,
you saved me from all that typing.
Old Nov 2, 2002 | 10:08 PM
HTownMaxSE's Avatar
Ok, thank you everyone. End of thread.
Old Nov 2, 2002 | 10:23 PM
97GLES's Avatar
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
