Pacesetter STS settings
Old Oct 30, 2002 | 10:03 PM
speedemn's Avatar
I have a 1995 Maxima SE 5-spd and just installed the Pacesetter short throw shifter. I was wondering what settings you guys have the shifter at. I guess you can adjust the height as well as the throw right?
Is there a point at which it could interfere with the exhaust, if it is set too low?
I just want to get an idea of the shortest setting that someone has it at without any problems with the exhaust and I would like to know what that setting is.
Thanks!
Old Oct 30, 2002 | 10:08 PM
97maximase5spd's Avatar
Just take off the heat shield and set it to whatever feels comfortable for you.
Old Oct 30, 2002 | 10:16 PM
speedemn's Avatar
Any other pros/cons to trashing the heat shield?
Old Oct 30, 2002 | 10:56 PM
meccanoble's Avatar
Sports Button FTW
i heard when heat shield is removed it gets real hot in that middle area.
For some reason after i had my y-pipe installed, my shifting has been a little loose and funny feeling. Not bad but it was real tight when i got the car and now its kind of loose. I thought i was killing the clutch but now i have other doubts....
Old Oct 30, 2002 | 11:26 PM
If your shifter feels loose, you better check under your car and tighten the bolt that connects ur shifter to the tranny linkage. That happened to me and eventually, as I was coming onto the highway, I downshifted into 2nd, tried shifting into 3rd and the shifter had broken loose from the tranny. I had to drive around in second gear for a couple of days until I got a replacement bolt from Nissan.
The reason why this happened was because a short shifter changes the fulcrum (?) or pivot point and the piece where the shifter connects to the tranny link was lower and hit the heat shield when I shifted (and it had been bent prior to this). I took the damnn thing off and noticed no heat increase. I'm sure if you tried really really hard you might see a very slight change, but I don't feel a difference. Better to have a little extra heat then be caught in one gear. I was lucky I was in 2nd and able to drive my car home. Imagine how much it would've sucked in 1st, 4th, 5th, or reverse...
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
