Does anyone know where I can find writeup on how to install ECTS?
Old Oct 31, 2002 | 09:23 AM
1Phat Max's Avatar
I got check engine light the other day and i pulled the code, i got code for knock sensor and Engine coolant temp sensor. I want to change ECTS first and c if that light comes bak again. Can anyone help? thanx
Old Oct 31, 2002 | 11:56 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
its really easy man
do you know where your coolant temp sensor is? If you look at your front valve cover, then to the right a bit youll see the 2 sensors. 1 small one is for your temp gauge, the bigger one is for your ECU control. i belieive the size is 19mm, juss wrench it off and put new one in. Coolant will come out, make sure you dont do it when its hot.
Cotozic
Jun 28, 2017 08:01 PM
Slamrod
Apr 10, 2016 05:24 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 7, 2015 05:57 PM
