spark plug problems :(
Old Nov 1, 2002 | 11:43 PM
cocolopez's Avatar
hey fellas, just look for some advice here. when i went to change my spark plugs, the boot was full of oil! it had leaked down into the plug and the damn plug was full of oil. there was oil everywhere, like the damn exxon crashed into it!
anyway, its only on i believe 2 holes, 2 of the back ones. i cleaned it up the best i could and threw them back in. the car was running better with the plugs, but anyhow, i dont know how the car was firing with all that damn oil. every once in a while, while im in idle, the car will "putt putt putt" a little bit.
any suggestions?
its a 95 maxima se btw
Old Nov 2, 2002 | 06:43 AM
Jamsan's Avatar
head gasket leak
id get that fixed asap
Old Nov 2, 2002 | 06:52 AM
JPMax's Avatar
What's next!?..
Sounds like the spark plug seals on those two are leaking.
You'll need to get the valve cover gasket and all 3 spark plug seals replaced. Do it ASAP..
Old Nov 2, 2002 | 04:53 PM
njmaxseltd's Avatar
It's not the head gasket!!
It's the valve cover gasket set he needs. I don't know if Nissan sells only one side or just the complete kit.
Old Nov 2, 2002 | 10:03 PM
95BlackMax's Avatar
Hey man dont worry all it takes is about 20 bucks for the seals... i just got done doing mine about 6 months ago.... you can buy a complete set for about 60-70 bucks if you want to go ahead and do both sides thats what i did just for the fact when i took everything apart all the seals were getting cracked anyway plus its worth the extra cash to go ahead and do it while you got the car apart. the back one is a ***** though... make sure you got a haynes manual though... helped me out alot. If I can help ya just email me and ill try to help as much as possible.
Old Nov 2, 2002 | 10:44 PM
meccanoble's Avatar
Sports Button FTW
probably might be kind of nasty
i had that same problem with my totaled max and i remember getting a cylinder 3 misfire. I bet you if your CEL light is one now, u hav a misfire on that specific cylinder. It hurt the performance of my car as well by a little bit.
car was still driveable but it was nasty.
Old Nov 3, 2002 | 04:13 PM
iwannabmw's Avatar
I second this.
Old Nov 3, 2002 | 04:56 PM
naijai's Avatar
Originally posted by iwannabmw
I second this.
third here say
Old Nov 3, 2002 | 05:15 PM
Sprint's Avatar
Originally posted by naijai
third here say
Old Nov 3, 2002 | 07:33 PM
+COLLANA+
valve cover gasket
aye. 5th.
Old Nov 3, 2002 | 08:36 PM
BBaker025's Avatar
get some of that silicon gasket or whatever its called. You just squeeze it on there and put the VC back on and problem solved.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
knight_yyz
Nov 6, 2015 02:34 PM
chernandez1278
Sep 16, 2015 01:18 PM
