Intake Air Temp Sensor on 95-96 maxima
Old Nov 2, 2002 | 11:57 AM
D1NOnly34's Avatar
OK, just put in a cone filter, where do i put the intake air temp sensor? I read a lot of threads on the 97+ maximas, but I think its different Im not sure. Right now I have the sensor INSIDE the filter, but he check engine light still comes on. (code 04 01) Pics would also be grea, thanks guys.
Old Nov 2, 2002 | 12:17 PM
gtr_rider's Avatar
192.168.1.1
might be helpful..
http://forums.maxima.org/showthread....ir+Temp+Sensor
Old Nov 2, 2002 | 03:18 PM
Shoooter_j's Avatar
all I did was ziptie the wires of the sensor to the cylindrical bottom of the filter so that the sensor was right next to the filter element.
This is what Frankencar instructions said:
"The sensor just needs to be close to the filter" or somethin along those lines.
Old Nov 2, 2002 | 03:26 PM
D1NOnly34's Avatar
What if the sensor is literally inside the filter? Not dangling, but put in a position where movement wasnt a problem, and in eh way of the air flow?
Old Nov 2, 2002 | 03:40 PM
Max-2-GTR's Avatar
I only screwed the sensor to a little piece of metal that I fixed to the body of the car with a few screws and place the sensor near the filter and that's doing fine for me.
Old Nov 2, 2002 | 03:45 PM
meccanoble's Avatar
Sports Button FTW
when i had my 95 GLE and i didn't have this plugged in, my engine light went on but once i plugged it in, it went off. Did you like abuse it or soemthing? maybe its damaged? u sure u plugged it all the way in? you talking about sensor you take off of stock intake right?
Old Nov 2, 2002 | 03:50 PM
D1NOnly34's Avatar
Yeah its the sensor on teh stock intake box. I didnt abuse it, at least I dont think. I have other codes thrown at me cause of problems with my knock sensor and stuff. But when I rant the ECU code check thing, the code for the intake sensor still pops up, I guess it will take a couple of days or something. I just hope that the way I have i is right and wont make anything worse.
Old Nov 3, 2002 | 03:19 PM
BOZOnPJs's Avatar
unplug your battery pos terminal over night and replace in the morning.. try that.
Old Nov 3, 2002 | 03:32 PM
gtr_rider's Avatar
192.168.1.1
I think that only works on 5th gens
Old Nov 3, 2002 | 07:23 PM
+COLLANA+
Reset ECU
just reset ECU and try taking negative terminal off for one night.
Old Nov 3, 2002 | 08:59 PM
Max4U's Avatar
I have the Frankencar with the Apexi filter on my 95, all I did was drill a little hole through the rubber that connects the filter adapter to the MAF and push the senser in the hole. It fits nice and snug and looks professional like it was made with the hole for the senser.
Clive.
mrc00l88
Jan 25, 2024 01:14 PM
maxinout93
Oct 27, 2015 01:29 PM
cheftoo
Aug 20, 2015 05:17 AM
egali045
Aug 5, 2015 09:02 AM
