my budget y-pipe is throwing 0305 (EGR temp sensor) code !!!
ok - every time i drive her hard check engine light comes on - i pull the same code over and over 0305 egr temp senor
i think it's becouse of the increased flow in the egr system
or maybe i need new sensor
anybody out there with similar problem ????
thanks for all help
Nick
thanks for all help
Nick
I put my budget y pipe on a year ago and have yet to have any codes
you could check the resistance of the temp sensor.. you could boil the sensor in water..
at 32 deg F it should be 7.9 Mega ohms - 9.7 Mega ohms
at 122 deg F it should be .57 Mega ohms - .70 Mega ohms
at 212 deg F it should be .08 Mega ohms - .10 Mega ohms
How do you know the temp of the water?? use a thermometer
and if you can't get 212 deg
look at replacing the sensor.. that is most likely the problem
lux97Max
Sep 4, 2015 05:42 PM
